D-icer and CAPAC Readings
#1 Posted : Saturday, January 16, 2010 11:02:08 AM(UTC)
Here is a new twist and I thought I had seen it all when it comes to Galvanic Readings.
This is the first year where ice in the marina has become a concern. This year I had close to 6 inches locking my M in tight. I began to panic a little when my shaft packing began drippin. (both developed very slow leaks and might have been from pressure on the hull)
Ok ...I put in a brand new Kosko 1/2 HP D-icing unit. It is slung under the hull at midship. It worked great and the boat was free in only a few hrs.
Now this is what I noticed. When the unit is on my CAPAC reading drops to .62. I turn unit off and readings return to my normal .92 reading.
This is an AC unit running through the ships electrical and through the galvanic isolator. It is also GFIC.
? Is the unit causing the lower readings when turned on because of?
A) Loss of potential which would be a potential corrosive condition or..
B) The turbulance created when the unit is running. (I know my CAPAC readings are way off under way)
Note: Readings are normal with unit off but submerged so it is NOT a disimular metal situation since the unit is isolated from the the hull except for electrical connection which again is grounded properly through the galvanic isolator.
Thoughts?
I figure I will not have the unit on for long periods of time. The ice is clear in my slip now and may not return unless we get another nasty cold snap.
#2 Posted : Saturday, January 16, 2010 12:24:58 PM(UTC)
Sounds like you have a slight voltage leak, or somewhere you are inducing a current into the hull, wiring, or Capac circuit. I'd first check that connections are all dry. Good luck, Ed
#3 Posted : Saturday, January 16, 2010 6:41:52 PM(UTC)
Dave,
Can U explain how the de-icer functions is it a bubble type or a heating element ? How close to the Capac senor is the de-icer mounted? If it’s mounted near it move it farther a way see if your reading change if they do then the unit is leaking a small amount of a electrical charge probably just enough to change the
readings ? The reason I mention this cause on my other Marinette 74 Express which had a dual forward scan of (168*) depth sounder & normal functioning sounder mounted thru the original depth sound hole in the hull when in forward scan the Capac meter read in ranges U described & when I’d switch to the normal sounder straight down the reading would return to normal just my ½ penny’s worth.
BTW when the De-icer free’d the pressure on the hull did the leak at the packing gland slow or
stop ?
Rick100
#4 Posted : Saturday, January 16, 2010 10:42:55 PM(UTC)
Rick100
Dave, It might be because the bubbles are creating air pockets around the sensor, therefore the sensor will not see solid water. Rick
#5 Posted : Sunday, January 17, 2010 1:43:27 AM(UTC)
I'm with Rick,
The GFI would catch any leakage and trip.
#6 Posted : Sunday, January 17, 2010 2:26:52 AM(UTC)
The D-icer or other trade name of Ice Eater is a very simple solution used for many years around docks, boats ponds etc.
It consists of an electric motor with a propeller that pulls water up from lower depths to the surface. This warmer water melts surface ice and circulates.
I agree I did more tests and there is absolutely NO voltage leak. I show no stray AC current and if there were any the GFIC would also be tripping.
The unit is slung under the boat about just below the keel mid ships which puts it very close to the CAPAC Cathode.
I moved the unit after and the readindings moved up and lowered it and the readings also changed.. so it must be effecting the readings due to turbulence. I am no longer concerned about it but thought it was interesting. After mky first post I remember checking readings while the boat was in motion (just idle spped) and the readings drop significantly. So just a false reading. Also the 1/2 HP motor the electromagnetic interference may also have an effect on the readings when it is running.
Doug Doty
#7 Posted : Monday, January 18, 2010 1:45:26 AM(UTC)
Doug Doty
Hope it did't chip up your gel coat all around the water line !! HA HA HA.. Plastic boater problem... You should of teased the other guys in the marina about.... " Thinking about go out for a ride "
440'S 19x22 wheels, 710 HOURS
#8 Posted : Monday, January 18, 2010 10:46:47 AM(UTC)
Hi Doug.. no problem but it did scrape up the anti fouling paint a bit at water line.
Ice is out and I doubt it will freeze in again this year.
#9 Posted : Monday, January 18, 2010 10:51:15 AM(UTC)
Dave,
stop ?
#10 Posted : Monday, January 18, 2010 1:08:01 PM(UTC)
Docsnow,
It was interesting. I always pull my shaft packing glands up a little to insure no drip during the off season.
Prior to ice.. the bildge was completely dry. (under a covered dock) Once the ice reached more than 4 inches I checked the bilger and noticed a VERRY slow drip from each gland. (one drop every 30 seonds)
Making no adjustments.. I put the ice deather in and the ice was gone in less than 8 hrs and next day I checked shafts and NO drip what so ever!
jimski2
#11 Posted : Monday, January 18, 2010 10:55:18 PM(UTC)
My AquaView Camera has a temperature indicator on it that I use for ice fishing. The temperature on the bottom under the ice is always 39 degrees F. Bringing the bottom water up is an easy way to clear the ice.
#12 Posted : Monday, January 18, 2010 11:31:31 PM(UTC)
My packing glands aren't dripping at all, OH Yea, I guess they wouldn't up on stands.
Sorry, I couldn't help my self.
#13 Posted : Monday, January 18, 2010 11:52:05 PM(UTC)
Dave,
Thanks for the come back on the packing seals glad it all worked good for U Applause
This page was generated in 0.172 seconds.
