"...should I remove the capac"
As noted above, it's not necessary if the Capac unit is working. But if you are blasting, cover it thoroughly. When my boat bottom was blasted, I covered the whole thing, plastic surround and all with an aluminum pie plate cut to fit (approx 10" dia) and fastened with several layers of masking tape. You don't want any abrasives near the center of the capac...ever. It's very thin metal (silver/silver chloride) and will be wrecked if you damage it. If you are ditching your other current transducers, no need to protect them. Not sure why you'd throw out a working instrument, though. You may appreciate a backup with your new systems.
5200: use it only where the installation will be permanent. But if you think you'll ever want to remove the sealed object, use 4200. (DIY magazine, however, has recommended a product that will remove 5200. I can't remember its name)
