Removal of button studs.
mytoy28
#1 Posted : Wednesday, February 10, 2010 1:48:15 AM(UTC)
Before painting the boat, I like to remove the existing button studs which are fastened with rivets, most of them will be deleted and the required ones renewed. The question is ?. Do I drill out the rivets & what material do I use to fill the 1/8" hole, so that it will not show through the new paint.
Thanks John.
rrbrown
#2 Posted : Wednesday, February 10, 2010 11:37:34 AM(UTC)
rrbrown
The yard that painted our boat last winter used Evercoat Metal-2-Metal filler to fill the small unwanted holes in the cabin top and deck. I would suggest you use a countersink to taper the hole so there is more surface area for the filler to stick to.
Rob
MISTY BLUE
1986 39' Marinette Aft Cabin
6.5 kW Westerbeke Generator
Home Port: New Buffalo MI.
#3 Posted : Wednesday, February 10, 2010 8:14:12 PM(UTC)
Because it was compatable with the primer, I used Interlux InterProtect Watertite Epoxy Filler.
See also: https://secure.internati...cht/GB_ISO_I_5000188.htm
mytoy28
#4 Posted : Thursday, February 11, 2010 3:01:34 AM(UTC)
Hi Dennis,
I am also using Interlux Brightsite, did you also countersink the holes for better filling as Rob suggested , and did the filled holes show through the finished paint.
Thanks John.
#6 Posted : Thursday, February 11, 2010 3:23:17 AM(UTC)
I had zillions of them, filled the holes with JB-Weld, Sanded the entire overhead to bare metal, etch coated and then sprayed on some Pettit Easy Proxy. That was 3 years ago and no problems.
I stuck some masking tape underneath so the epoxy would not drip clean through the hole and end up where you don't need it.
#5 Posted : Thursday, February 11, 2010 10:29:16 AM(UTC)
mytoy28 wrote:
Hi Dennis, I am also using Interlux Brightsite, did you also countersink the holes for better filling as Rob suggested , and did the filled holes show through the finished paint.Thanks John.
It is a good idea to countersink them. I used a drill bit chucked into a T-handle ratchet hand tap. A couple of twists with a sharp bit will do it.
This page was generated in 0.151 seconds.
