A tip on removing exhaust systems
#1 Posted : Tuesday, February 23, 2010 1:32:44 AM(UTC)
From FastJeff:
A tip on removing exhaust systems: Drain the coolant from the engine, the manifold and the risers FIRST or you will get water in the motor through the exhaust ports.
A tip on installing manifolds: Make up a couple of long studs with a saw cut in the end for a screw driver. Put these in the ends of the head, slip the gaskets in place, then the manifold. Much easier! Then install the bolts before removing the studs.
Final tip: Try to buy exhaust manifold gaskets that are ONE PIECE! Some are three piece, and those end gaskets will drive you batty! Then can go on a dozen different ways, but only one way won't leak. Also, don't buy 318/ 360 automotive exhaust manifold gaskets--the ports are too big and they will leak. My favorite gaskets are those used on early 273 cube Mopar V-8s--one piece, and the ports are much smaller. (I had a part number for it but it's no longer valid.)
Finally, I use grade 8 steel bolts (not stainless) with lots of anti-seize on the threads, and I clean the head threads out with a tap if they need it. (If the bolt won't screw in by hand, they need it.) Tighten them down, run the motor, then tighten them down again. They'll need it.
This page was generated in 0.061 seconds.
