What is above the rub rail?
minnesota dan
#1 Posted : Thursday, October 02, 2008 1:28:16 PM(UTC)
Rank: New Poster
I apologize in advance for the vague subject line. As I read the following I realize it may be difficult to follow, please feel free to ask for clarification, no offense will be taken.
I need to know if the bump in the deck just above the rubrail on a 41 Marinette is solid or not. This bump up is to assist in the channeling of water on the deck to the rear of the boat. The problem I am having is that the water does not fully drain from this channel and I have about 6 inches of water about 1/8" deep that accumulates on the boat on a daily basis. It is on the NE side of the boat and the sun does not get there at all to dry it out. The water has accumulated at the extreme rear of the boat and has lifted up Awlgrip paint. Awlgrip rep claims this is an issue because Alwgrip top side paint is not designed to be under water. I need to get this water to drain out fully.
I was planning to cut a small kerf in this bump to allow the water to fully drain out. I need to know if any one knows if this bump is solid or not. If I cut the kerf and bump is not solid then I will need to fix the cut and then go to plan 2.
Plan 2 was to put a small drain hole in the deck and route it to the hull to drain over board. I am not sure of the access to this area from the inside. I have already removed the failed Alwgrip paint and need to repaint this area. I was thinking about a 1/8 inch drain hole.
I would also appreciate any information any may have on this and additionally if anyone has addressed this issue in some other manner.
Thanks in advance
Dan
#2 Posted : Thursday, October 02, 2008 2:13:06 PM(UTC)
Minn.Dan,
I’m not positive but I’d say it would be a solid piece of 1/2 round stock Think ahh it just came to me take the
smallest drill U own say a 1/16" & drill thru depth of the round where U plan on cutting the kerf but not the deck U’ll soon find out if it’s hollow or not. Pray If & when U do this chore how about letting the rest of the forum know the out come Brick wall so we don't have to do thisBrick wall
BigBigMs Live On Applause
rrbrown
#3 Posted : Thursday, October 02, 2008 5:15:01 PM(UTC)
rrbrown
Dan,
We have the same problem on our 39. The bump you speak of is not solid, it is a extrusion and you would probably cut through it before you could get all of the water to drain. There is a cross section of the hull in one of the brochures on this site that shows it. I was thinking of raising the area by fairing it forward far enough to allow the water to run over the top of the bump.
I can email you the picture if you can't find it.
Rob
MISTY BLUE
1986 39' Marinette Aft Cabin
6.5 kW Westerbeke Generator
Home Port: New Buffalo MI.
bpboater
#4 Posted : Friday, October 03, 2008 2:13:50 AM(UTC)
For just this small area, consider using a different paint that can be kept underwater - epoxy bottom paints are designed for this.
clarko
#5 Posted : Saturday, October 04, 2008 12:37:59 PM(UTC)
clarko
click on "search" in the logged in as: line and then type in "old Marinette brochures". There is a whole pot full of brochures that I and several others put on there. Scroll down, waaay down and you will come to pictures of construction of the hull. It shows the extrusions. The bump or gun'l is hollow and the deck slides into it on one side and the hull slides into it on the other. If you drill or cut the bump it will drain directly into the hull. It is always interesting to look at all the brochures and see the different layouts.
Goldpoint
#6 Posted : Monday, November 24, 2008 11:08:43 AM(UTC)
Goldpoint
I almost didn't find this post this evening....
I was rooting around on my boat a bit earlier and found a couple of cross-sections of hull construction laying in the bilge area under the forward bunk. I guess these were used as sales tools back in the day to provide some detail on construction. Just a guess. I took a couple of quick photos. Will try to get some better ones later. This cross section of the extrusion with deck and side pieces welded in should answer the question concerning what is under the 'bump' on the deck. The other cross-section appears to be the keel.
John B.
Goldpoint attached the following image(s):
Goldpoint attached the following image(s): Hull_Extru_2.JPG
1979 28' Sedan Bridge
Single 360
Chattanooga, TN
#8 Posted : Monday, November 24, 2008 12:51:40 PM(UTC)
John,
Nice post! I've seen that in drawings but it's good to see the actual material.
#9 Posted : Tuesday, November 25, 2008 12:34:14 AM(UTC)
Awesome photos!
When I sanded the deck to raw aluminum it looked to me that my BigM had a red rubber between the deck and the upper part of the extrusions U. This coud have just been a thick primer coat but the only place I found it was near the rub rail. Either way it would seem that welding eiher side would have cooked either material away.
#10 Posted : Tuesday, November 25, 2008 2:41:55 AM(UTC)
Wow. No wonder these boats are so solid. These interlocking Marinette extrusions are amazing. They tie the two halves of the hull and the deck and gunwales together and provide a continuous interlocked and welded connection, not just where a screw would be like on a typical fiberglass seam.
#7 Posted : Tuesday, November 25, 2008 7:40:47 AM(UTC)
Goldpoint wrote:
...will try to get some better ones later. John B.
Thanks for taking the time to post the pictures. They are like Xrays.
Goldpoint
#11 Posted : Tuesday, November 25, 2008 9:27:33 PM(UTC)
Goldpoint
A few more photos of those two extrusions that are a bit better. Looks like the smaller cross-section is the extrusion used to join the bottom to the side. Note the difference in metal thickness of the plates.
Goldpoint
Goldpoint attached the following image(s): Hull_Extru_3a.JPG
Goldpoint attached the following image(s): Hull_Extru_4a.JPG
Goldpoint attached the following image(s): Hull_Extru_5a.JPG
Single 360
Chattanooga, TN
#12 Posted : Wednesday, November 26, 2008 3:26:14 AM(UTC)
Now, that photo I can understand. The other ones are still confusing.
Thanks for posting!
#13 Posted : Wednesday, November 26, 2008 9:55:57 AM(UTC)
Good job on the photos
#14 Posted : Wednesday, November 26, 2008 10:09:27 AM(UTC)
Yes...great!
Norm dosen't even need his quad-focal glasses.
My topside deck was not welded though. I've got that red rubber stuff on top and too much black crap underneath to tell if it was welded there. Maybe it's just JB Welded together...
Jazman
#15 Posted : Tuesday, January 06, 2009 2:50:45 AM(UTC)
Jazman
I found this while surfing for BigBigM info thought it might help.
Killer extrusions, fairly heavy plating and all welded... no wonder they are TOUGH!
Fenders?? We dont need no stinking fenders!
Jazman attached the following image(s):
Jazman attached the following image(s): Metals1.jpg
1975 37' FB Sedan
Sleepless Knights
Bohemia River
Chesapeake City, MD
mark
#16 Posted : Tuesday, January 06, 2009 7:54:53 AM(UTC)
mark
drilling a hole will cure the problem of the water standing i to have this on my 32 but the hole needs to be big enough so that it does not clog up with just normal dust and lint the drain holes in the front of the 32 look like 1/4 but they still clog with dirt and spiders, if you do put a hole in it make it big enough for like a #3 an fitting x 1/8 npt and put the fitting up from the bottom to flush off with top skin with a little piece of screen in it and then you could plum it to any drain you wanted fitting woud be 1/8 npt male by #3 an male (3/16) and also would be aluminum
mark
#17 Posted : Tuesday, February 23, 2010 5:03:55 PM(UTC)
cap'n Brent
#18 Posted : Wednesday, February 24, 2010 12:59:16 AM(UTC)
cap'n Brent
dont drill ! ! i have a 32 with same issue what i think you need to do is as fallows buy a 45 gallon keg of C/M spiced rum and a spunge and put the keg on affected aria so she sits lower in the water then i will come by and sop up the standing water and drink all your rum repeat as neccary
Capt T
#19 Posted : Wednesday, February 24, 2010 1:36:10 PM(UTC)
Capt T
Now that's a kind fellow BigM owner. willing to sacrifice his time for a little refreshment. Nice offer Capt Brent.
I was pondering doing the cut out and asked about it last year, decided against it, someone said i may run into structural issues. Glad to see the pix in this post. Me thinks I may look into the drain hole idea as well.
1978 Aft Cabin
Twin Chrysler 440's
Fox Road Marina
This page was generated in 0.576 seconds.
