I bought a 1974 SAAB Sonnett a couple years ago and the gas tank was totally messed up. I pulled the tank, took out the sending unit and dumped probably two gallons of sludge and stuff that looked like white paint chips out.. Then I washed it out with my hose, threw a bunch of nuts an bolts in it and sloshed it around, banged on the sides with a rubber mallet, and washed it out again. I repeated this until not another speck of crap came out. Then I took it to a self serve car wash and blasted it out with high pressure water and soap for about ten minutes. Took it home, plugged a hair dryer in and let it run in the big hole for like a half hour or forty five minutes.. Then I took a torch and heated it up all over an watched whatever remaining water there was evaporate. Reinstalled and never had another issue. So how to do this on a Marinette without pulling the tank.. The first thing is how to drain it completely and get all the crap out before you start flushing it with water.. I don't think there is a 3 or 4 inch fitting on the bottom side to remove and drain is there? If you could, then I would get a snake like you use to clean a floor drain and put it in through the top, like at the gas gauge opening..It does come out, doesn't it? Then put the snake in there and just let it rattle around in there and flush it with water, and repeat till nothing else came out. Then just dry the crap out of it. Hair dryer, block heater, what ever I could fit in there to heat it up.. That's my theory.. But you have to get all the gas and crap out and start flushing with water or you'll have a big bang theory on your hands..And face.. And everyone else in the marinas hands and face.. Probably better to pull it.
SIFF SURF
1972 32' FB Express
