fridge & ice maker
#1 Posted : Friday, May 07, 2010 2:45:50 AM(UTC)
I'm looking for a device to let one appliance operate at a time when I'm on the inverter. Anyone know of one that will just plug in and allow two appliances to plug into it? I could do it with a current relay, but I think there is already something out there and would be much neater than what I would make.
Doug Doty
#2 Posted : Friday, May 07, 2010 6:02:44 AM(UTC)
Doug Doty
Not exactly what you are asking for but plug in timers and stagger the settings would do this.
440'S 19x22 wheels, 710 HOURS
jimski2
#3 Posted : Friday, May 07, 2010 11:12:02 PM(UTC)
An alternating appliance switch is something that could be patented and make you the owner of a newer bigger Marinette.
#4 Posted : Saturday, May 08, 2010 12:38:48 AM(UTC)
The galvanic isolator protects stray DC current from entering the Green AC safety ground. You can safely have both your 30 amp and gen. circuits connected to the Green safety ground. AC current does not flow through the isolator.
#5 Posted : Saturday, May 08, 2010 1:41:58 AM(UTC)
Load management for generator-driven loads is common on large boats, and I used to make a box that did that. It was not sophisticated, just a pair of sockets wired so that if one was drawing current, the other was off. This is useful for turning off a water heater when the ac is running, so that the generator does not have to be sized for the combined load. We decided that there was little market for such a simple unit, so we only made 10 or so.
Today, the cost of inverters has come down so much that I am not sure there is any need for it. It is likely cheaper to just get an inverter that is large enough. 3kw matches the shorepower and a true sine-wave inverter for that can be had for around $400.
Interestingly, computer suppliers sell a similar thing that looks like a power strip, but with one "sensor" plug and a bunch of slave plugs. You can plug your monitor into the "sensor" plug, and all the other computer crap into the slaves. Then, when you turn your monitor on (or off) the whole magilla turns on (or off). I haven't tried one, because I have a laptop, but it might work onboard.....
#6 Posted : Saturday, May 08, 2010 9:21:45 AM(UTC)
I have a 1700 watt inverter and it probably would run both if they didn't try to start at the same time.
I was thinking that "way back when" The rual electric Co's had a limiting relay to prevent larger loads from operating at the same time. Like Doug said, Water heater & air conditioning, etc. The ice maker is only 2 1/2
amps run but start is 6-10 times run current.
Doug, You are right, just look into a larger inverter & add another battery.
This page was generated in 0.251 seconds.
