Dehumidifier
shsteev
#1 Posted : Tuesday, May 11, 2010 10:24:50 AM(UTC)
Bought one of those small dehumidifiers for the boat .Model- Eva dry 2200 with that no compressor system.It has a very quiet fan and a heat sink looking plate .I think they call it Peltier technology.So far the little sucker is working GREAT! shuts off automatically when full.It fits in the sink, very compact.The ac adapter gets very warm but I found that by setting it on the stainless stove cover it will dissipate a lot of the heat from it.In combination with the solar powered vent fan that runs 24/7 The interior stays nice and dry with no mildew or must . I would recommend it to anyone wanting a nice dry living environment.
#2 Posted : Tuesday, May 11, 2010 11:27:47 AM(UTC)
The reviews on Amazon look real good for that dehumidifier. My only problem is, I only get to my boat about every two weeks Brick wall. The fill tank would be full in a couple of days so it wouldn't do me much good. I'm currently using the large Damprid bucket you can get at Home Depot for about $10. Not sure how long it will last during the humid summer here in TN. I'm thinking your little humidifier would cost at least $10/month in elec to run.
If you could bypass the tank switch on your Eva dry 2200 and put it in the sink to drain into the holding tank that would be ideal. Give a look and see if it's possible. Anyone here see a problem with my suggestion? How about this, instead of bypassing switch, drill a hole and attach a drain tube to the tank into the sink drain. What do you think guys?
#3 Posted : Tuesday, May 11, 2010 2:42:35 PM(UTC)
also..the water that the dehumifier accumulates is distilled so you can use it in your battery (and your clothes iron) and be generous to your neighbors.
Sure, why not put in a hose that runs into the siunk where it will run overboard. (after you've accumulated some distilled stuff.
#4 Posted : Wednesday, May 12, 2010 3:06:17 AM(UTC)
I wish I had seen this a year ago. I now have a small AC to dehumidify the boat (and cool some) but I think one of these would have been adequate.
One big problem with my AC is the electronic controls. If power is lost, it DOES NOT COME BACK ON automatically, someone must push the button on the panel. This is a terrible problem where brief power outages are common.
So, my question: If you disconnect the power and reconnect, does the unit resume working?
I would likely want to run it from ac power, probably no problem, just need a small power supply.
I think I would just run the water into the bilge, where it will be handled by the bilge pump in due course.
#5 Posted : Wednesday, May 12, 2010 3:34:29 AM(UTC)
" I would just run the water into the bilge, where it will be handled by the bilge pump in due course.."
uh-uh.
#6 Posted : Wednesday, May 12, 2010 3:35:48 AM(UTC)
Yeah, probably not a great idea. But I like the sink drain idea.
#7 Posted : Wednesday, May 12, 2010 4:07:03 AM(UTC)
Here's Amazon link
http://www.amazon.com/Eva-dry-Edv-2200-Eva-Dry-Mid-Size-Dehumidifier/dp/B001QTW6KQ
Eva dry web site link here
#8 Posted : Wednesday, May 12, 2010 4:25:07 AM(UTC)
If you have an A/C unit on board, check the manual. I discovered that mine has a dehumidify setting that will keep the boat dry and odor free while we are away. The downside is that you are cycling a compressor on and off while the boat is unoccupied.
shsteev
#9 Posted : Wednesday, May 12, 2010 9:50:21 AM(UTC)
Doug,I will check this weekend to see if I drop the power then turn back on that the unit comes back on by itself.I was considering removing the collection hopper and letting the condensate run out the drain .It is an option as there is a micro switch that is activated by a float on the collection hopper and if you remove the hopper it will constantly run.But like Joel said you can use the distilled water. plus I am at the boat weekly to empty.
#10 Posted : Wednesday, May 12, 2010 10:05:09 PM(UTC)
I have read some of the comments on this unit and I believe that it is too small for a 32' in Florida. Even with the thing running constantly, it will probably not handle the 100+ humidity down there - I sometimes pull a couple of quarts a day out of the boat. The A/C that I now have is also a dehumidifier, and I have the condensate running overboard. Still, the Peltier cooler is very attractive (used a lot in the space business) since it has no moving parts. It is about 17% efficient, whereas a compressor can run up to 50%, in creating cold, but that does not matter so much for a dehumidifier. I like the idea that it can run on 12V. I could eliminate the little power supply and wire it in directly, perhaps.
shsteev
#11 Posted : Saturday, May 15, 2010 8:28:01 AM(UTC)
Went to the boat today and the dehumidifier is still purring.The condensate hopper was a tad over 1/2 full.It had rained for three days straight prior to checking.The air seemed dry.Cabin temperature was 70 degrees, relative humidity was 45 percent!
I threw the main breaker off and the unit quit .When I reset the breaker unit came on by itself.So that is good if there were to be a temporary power outage.
#12 Posted : Saturday, May 15, 2010 12:12:16 PM(UTC)
One caution on using dehumidifiers: You need to cover the tank so the water doesn't re-evaporate on you. I used a dehumidifier for years in my cellar and covered its tank with a hunk of wood, leaving a space for the condensate to drain down into the tank. Later I got smart and hooked the tank directly to the sewer.
This page was generated in 0.164 seconds.
