Several weeks ago we hit a submerged object with the starboard prop. I decided to see if i could change the prop in the 4 foot deep water where "Church Belle" is tied up. With my long arms I can reach under and touch the prop without putting my head under water. The problem was getting the puller connected.
I made two modifications to the puller. First,I ground the tips so that they would fit between the line cutters and the prop hub. Second thing, was to create spring tension across the arms so that it only took one hand to push the puller over the prop into position. I used a small ball bunge to make the tension.
With the shaft nut half threaded on to hold the puller screw in place, the puller easily slipped into place. With the screw tightened snug it only took one hit to the prop hub with a big hammer and she came loose.
As you can see from the photo, only one blade has no damage.
Richard Wiley
"Church Belle" '76 37' FB Sedan
Twin Chevy 350's Electronic fuel injection
18x18 props
