Thru-hull transducer type
frank ardis, jr.
#1 Posted : Wednesday, May 26, 2010 4:45:22 AM(UTC)
Rank: New Poster
I have 32 sedan bridge. I am going to install a depth,fishfinder and gps combo unit on the bridge. I have been told by various people including different West Marine staff as to the type of thru-hull transducer required. The issue is either plastic or a brass/wood block type. The boat is used on Lake Erie. All help is appreciated.
#2 Posted : Wednesday, May 26, 2010 5:27:32 AM(UTC)
Frank..there are many posts on site about transducers including a recent thread (use the search function). To summarize: material doesn't matter ...except, if you use bronze it MUST be totally isolated from the hull. Isolating material on the outside might include a plastic or rubber (though some don't like rubber because if does carry some tiny current). The shaft of the unit going thru the hull must not touch the hull (the hole must be over sized) and isolation on the interior could be a wood or plastic fairing block (I would prefer plastic since it will never rot in a damp/wet bilge). Lots of sealant.
BoatUS just posted a transducer how-to on its web site.
#3 Posted : Wednesday, May 26, 2010 7:06:40 AM(UTC)
Frank,
If U have a lower helm GPS & depth finder there is a selector switch that’s available that allows U to run off one thru hull but U still need two GPS antennas all my paper work on the switch & GPS is 220mi. away. But if U ask at a better boat electronic store they may be able to advise U. wish I could’ve been more help. AnyWho that’s how my two units work they’re Furno 1650F’s color. Have fun running the wires up the tube Brick wall
Just a suggestion while U are at it run a couple of extra fine wires up at the same time so the next time U won't have mess around I used steel fishing line 80lb test dia. about .30 works great Anxious
#4 Posted : Wednesday, May 26, 2010 7:29:16 AM(UTC)
Frank:
When you run the wires to the bridge, open the overhead wooden breaker panel in the ceiling.
You will see that the pipe is not continuous. It's 2 separate pipes. One from the wine cellar to the space above the headliner and another pipe that goes through the aluminum roof to the bridge.
The pipes are not aligned.
#5 Posted : Wednesday, May 26, 2010 7:41:04 AM(UTC)
When running wires through a tube some light fishing line, a piece of sponge , an old nylon stocking, and a vacum cleaner with a hose works wonders.
Put the nylon over the end of the vacum, tie the sponge to the fishing line, have your helper vacum one end of the tube and stick the sponge in the other. Within a minute the sponge will work its way through to the nylon, if your fisherman keeps paying out line. Now you can pull through a heaver line and follow that with the wires.
#6 Posted : Wednesday, May 26, 2010 9:37:21 AM(UTC)
If you use a nylon ducer don't use a wood fairing block. The wood can expand and crack the ducer.
Either use Starboard or Plasteak.
Just my 2 cents.
#7 Posted : Wednesday, May 26, 2010 10:50:35 AM(UTC)
Airmar makes almost all of the depth transducers so I strongly recommend you spend some time on the Airmar website. You start with the thruhull unit you want and cross-reference to the OEM that makes the readout unit you want. Then special order it if they don't keep it in stock. I like the retactable housing used on the DST800 and DT800. You slip in the type of pickup you need depth, speed, temp etc. A new model even has a camera. If you want to upgrade or change OEM's you just buy new inserts. If you start top-down with the OEM all you get is the cheapest transducer they can put in the box. The retractable units fit in a 2" hole in the hull. The cheap thruhulls are 1 7/8'. These units are low profile - almost flush - forget fairing blocks. Get the plastic housing. New units also have the NMEA 2000 electronics built right in. Here is an Airmar brochure for the DT800 Hummingbird.
http://airmartechnology....d=69&manf=Humminbird
This page was generated in 0.142 seconds.
