Prop change while in water
Richard Wiley
#1 Posted : Monday, May 24, 2010 1:45:52 AM(UTC)
Richard Wiley
Several weeks ago we hit a submerged object with the starboard prop. I decided to see if i could change the prop in the 4 foot deep water where "Church Belle" is tied up. With my long arms I can reach under and touch the prop without putting my head under water. The problem was getting the puller connected.
I made two modifications to the puller. First,I ground the tips so that they would fit between the line cutters and the prop hub. Second thing, was to create spring tension across the arms so that it only took one hand to push the puller over the prop into position. I used a small ball bunge to make the tension.
With the shaft nut half threaded on to hold the puller screw in place, the puller easily slipped into place. With the screw tightened snug it only took one hit to the prop hub with a big hammer and she came loose.
As you can see from the photo, only one blade has no damage.
Top & Prop 011.jpg (510kb) downloaded 143 time(s).
Top & Prop 009.jpg (522kb) downloaded 126 time(s).
Top & Prop 007.jpg (565kb) downloaded 123 time(s).
Richard Wiley
"Church Belle" '76 37' FB Sedan
Twin Chevy 350's Electronic fuel injection
18x18 props
#2 Posted : Monday, May 24, 2010 2:58:07 AM(UTC)
Well done, sir.
#3 Posted : Monday, May 24, 2010 4:44:53 AM(UTC)
Gutsy!
I would have dropped something!
#4 Posted : Monday, May 24, 2010 5:43:35 PM(UTC)
The problem I have always had with gearpullers is that the screw sticks back and interferes with the rudder, so I can't get the thing on straight. I notice that you have quite a long screw on yours. How did it fit past the rudder?
Richard Wiley
#5 Posted : Tuesday, May 25, 2010 1:21:00 AM(UTC)
Richard Wiley
The screw did extend over the rudder on the outside and missed it by one inch.
Richard Wiley
18x18 props
fishnatic
#6 Posted : Tuesday, June 15, 2010 2:36:30 PM(UTC)
might want to check shaft and strut when you come out next.
#7 Posted : Tuesday, June 15, 2010 11:08:07 PM(UTC)
Looking at the first photo I thought, "how did he get a 3 blade prop off with that puller?" The next photos told the tale!
PS: No way my props would come off that easy, however. I had to use heat and a puller to get one off.
Richard Wiley
#8 Posted : Wednesday, June 16, 2010 1:25:41 AM(UTC)
Richard Wiley
Good advice Fishnatic. We plan to haul out next month for a complete inspection and replacement of the anodes. We make the 125 mile trip up to Applegate Cove Marina (www.applegatemarina.com) near Sallisaw Oklahoma where they have a boat lift.
Jeff, with the tapered shaft it shouldn't need heat to break the prop loose.
Regards,
Rich
Richard Wiley
18x18 props
#9 Posted : Wednesday, June 16, 2010 2:20:17 AM(UTC)
..."...with the tapered shaft it shouldn't need heat to break the prop loose."
Wanna bet! That sucker was really on.
PS: Note that three bladed props need a different puller than the one pictured; it will only work on 4 bladers.
Domino
#10 Posted : Wednesday, June 16, 2010 1:15:06 PM(UTC)
Domino
better man than I ...Gunga Din.....great job!
Domino is on the hard @ Pier 500 Marina, Wyandotte, Michigan
** 67 32' Express
** Ford 302's
#11 Posted : Thursday, June 17, 2010 4:17:13 AM(UTC)
My props really stick and I will let the marina pop them for me. They have a hydraulic pull that I could never afford.
#12 Posted : Thursday, June 17, 2010 5:52:06 AM(UTC)
To All,
They have a prop puller they sell on the web that works great.Applause @ about $150 so a little of Jeff, rubbed off on me & I made my own outta scraps I had laying around a it looks ugly as hell but works just as good Applause& only cost about $10 & my time Whistle here's a pic of store bought (black) first pic than my ugly puller Anxious both work slick put the U cut out between the strut & prop screw nut out on shaft to protect the threads put the 3 threaded rods between the blades to connect the the front plate tighten up on the 3 nuts equally give the plate a rap with a ballpeen hammer & off comes the prop can get both props off in less than a half hour Applause making this gem saved me enough for about 10 cases of brewski's Shhh plus untoll #s of freeeeee brewski's by lending it out Angel one of these days have to make a fancy dan one like the store bought one Not talking AnyWho it works great for me Drool
Props come off easy with ugly pullApplause
the wood one is for pushing strut bearing back in Whistle
Puller # 2.JPG (215kb) downloaded 126 time(s).
Puller #1.JPG (214kb) downloaded 121 time(s).
Docsnow attached the following image(s):
Docsnow attached the following image(s): My Pictures 991.jpg
#13 Posted : Thursday, June 17, 2010 9:24:14 AM(UTC)
Man, I'm so proud of you! Mine looks about a cobby, and it works great as well.
#14 Posted : Thursday, June 17, 2010 9:36:19 AM(UTC)
I've used prop pullers like that, have also found that a 3 jaw gear puller worked fine for a 3 bladed prop. Don't be surprised if you have to put some heat on the prop to get it to pop loose. And just hope you don't have pull the prop. Better things to do with your time and money.--Ed
This page was generated in 0.590 seconds.
