Here's the latest update. Jeff has a diagram that I used to plan my strategy. Maybe he can attach it on this thread...
Replaced the Chrysler boxes with NAPA 4-pin units. $23 each.
http://www.napaonline.co...01+101980+50022+2022024
Replaced the coils with MSD Blaster High Vibration Ignition Coils #8222. Summit Racing. $46 each.
http://www.summitracing.com/parts/MSD-8222/
Had to use a .8 ohm ballast resistor, because I retained the factory ignition system. MSD wanted to use theirs, #8214,
http://www.summitracing.com/parts/MSD-8214/
BUT I OPTED TO USE THE ONE FROM MALLORY INSTEAD, Part #700, because it has post terminals with nuts. A MUCH better connection. They list theirs as a variable resistance of .7 to 1.5 ohms. I have a feeling that MSD's is variable too - they just don't say so. Either way, it's close enough and it looks like better quality. $17 each. I actually got it price-matched at Advance Auto Parts.
http://www.summitracing.com/parts/MAA-700/
Lots of dielectric grease. Especially in the module plug and coil tower! $3 tube.
I removed the 5 pin modules and factory resistors (dual, 4 pin) - some of you only have single 2-pin resistors.
I cut out the 5th wire to the module, since it was no longer going to be used. This wire provided about 9v to the module, though we don't really know why...
I cut out ALL redundant male/female quick disconnect pigtails. Less connections, less problems.
New ballast resistor gets RING terminals (not spades). Better connection.
Check and replace existing coil terminals, as needed - mine were OK.
CHECK THE CABLES AT THE SOLENOID - MY STARBOARD BATTERY CABLE WAS LOOSE :(
Might have been some of the problem, on that engine, but the original COIL WAS LEAKING as well, probably giving me the breaking-up-at-2800rpm issue...
RESISTOR TERMINALS WERE LOOSE, on the original Port ballast resistor. This caused my tach to go nuts, and probably because the engine was cutting in and out. NOT GOOD. This was solved with the ring terminals and new resistors.
All told, I have about $190 Total invested. That's HALF of what it cost me to get pulled and repair 1 prop, damaged from backing into the rocks, when I lost an engine. Cheap insurance, if you ask me, to get rid of a lot of the Chrysler shortcomings.
BTW - During a 2 day, 20 mile round trip, we cruised at about 4000rpm out and 4600rpm back. Not a hiccup whatsoever, and even the tachs were more stable than they've ever been :)
1987 32 Sedan Bridge
Twin 360s, Rebuilt 2006
Raw Water Cooled
Catawba Island, Ohio
