Joined: 3/2/2008 Posts: 56 Points: 80 Location: sanford,mi. boat on lake huron ,at oscoda
capac deflects downward when bilge goes on? what to do?
, Member
Joined: 12/5/2007 Posts: 2,540 Points: 4,534 Location: New Tripoli, PA
I suspect the ground return for the bilge pump is going to the hull instead of ground lug the batteries ground at. Not a big difference, but enough to effect the readings.
"If you put the federal government in charge of the Sahara Desert , in five years there’d be a shortage of sand.”
~ Milton Friedman
took a quick look last weekend wires all head toward stern, may investigate more this weekend to see if i can find ground location,thanks Jeff P,s. whats the difference of grounding at lugs vs. the hull,same surface?
, Member
..."...whats the difference of grounding at lugs vs. the hull,same surface? "
It's subtle, but there is a"conductor path" difference, especially if it's several feet long.
~ Milton Friedman
Guest2 |
