Question:
1. Did you replace an existing charger?
2. If you did was it a marine charger you replaced or something else?
Questions:
New Anodes lower readings.
1. Replacing anodes will not improve readings if there are isolation issue which require attention.
Go back to basics and check isolation of shafts, galvanic isolator etc. Also check calibrationn of your meter with high quality meter
Question:
Your readings improved when you moved.
It would appear your had some other boats with electrical problems or problems withh the dock current at previous location.
That is not uncommon. It is amazing how many folks have no galvanic isolators (probably 95 percent) and used cheap automotive battery chargers which are very dirty. Also take a walk down your dock and look at some of the shore power connections...you might be surprised how unsafe some are!
