Well, I'm convinced God must own a
!! He smiled on me...
Took the boat out into the Ohio (where the "icky factor" is much less than sittin' in the marina). Couple of dives under the boat found nothing wrong (that feeling around could verify) on the port system (shaft, rudder, prop). Starboard side came up with one blade of the prop having a 2 - 3 inch bend in the edge. So it mush not have been too big a log and/or was in pretty sad shape and the prop was able to cut thru it. I was able to straighten most of the deformity but once I get something more solid as a "backer", I should be able to shape it back to almost normal under water.
Would there be a preference as to what material would be best suited as a backer? Normally, I'd go with steel but given the nature of Marinettes, I thought it best to ask the forum first.
Either way, it looks like another prolonged period holdin' my breath. If I was younger, I'd have this down pat...
... my mom said I could hold my breath quite a long time.
... but then, she'd just caught my brother and I sneaking her smokes!
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
