Has anyone installed a power vent into the head of a 32'. I've spent enough time to determine that it's stuffy and not very well vented (tho there's a static vent in the overhead).
I'd thought of installing a larger 12v PC fan controlled by a switch which would be powered from the cabin light in the head.
Questions:
1. Has anyone ever cut into the bulkhead bordering the anteroom section of the head which borders the walkway up to the fwd berth? I was going to mount the fan in that area if it's clear of vertical supports (and it puts it outside of the shower area itself).
2. What's the challenge in routing a set of wires to the light fixture?
- I'd like to snake a set of wires down the bulkhead to install a rubber covered switch to allow for control of the fan. This'd force air from
from the main living area (air conditioned / dryer air) into the head area.
Comments? Suggestions?
" Sunset Seeker "
1988 32' Fly Bridge
Raw water cooling
Freshwater boat
