From BarkleyDave:Here is a simple way to check isolation. (It is also on a metal plate on many Big M's)
1. Make up a jumper cable with clips on each end.
2. Check your Capac reading. example: .90
3. Connect jumper to shaft coupler on the shaft side
4. Connect other end of jumper to hull or engine block etc.
5. Check readin again. If shaft was isolated the reading will deflect downward. Example: .60
Shaft isolated = Reading deflects with shaft is grounded to hull
Shaft Not isolated= Reading remains the same does not deflect.
(well written, Dave)
