2 Pages12>
IGNITION UPGRADES (Originally titled MSD Igntion & Tachs)
jsimanella
#1 Posted : Monday, May 31, 2010 3:43:51 PM(UTC)
jsimanella
(SCROLL DOWN, FOR THE SOLUTION TO MY ISSUE. I DID NOT DO THE FULL MSD CONVERSION...)
Did a search and came up a little light.
Still having intermittent problems. Definitely ignition related. Tired of these BS Chrysler ignitions.
Has anyone done the MSD conversion? What do I need to know? Specifically, how will it work with my 1987 tach & sync setup?
I want to jump on this ASAP - tired of "not knowing" what to expect when I head out for the day :(
Thanks!
1987 32 Sedan Bridge
Twin 360s, Rebuilt 2006
Raw Water Cooled
Catawba Island, Ohio
Doug Doty
#2 Posted : Monday, May 31, 2010 6:08:01 PM(UTC)
Doug Doty
I love MSD ignition, you will be able to tell a difference instantly, the 6A box's are rock solid dependable and have a specific tach output terminal that has never failed to drive a tach for me. My personal experience is all in several different cars but all positive. The fella docked next to me put MSD on his twin engine house boat years ago and it always worked flawlessly until it sunk from marina snowload 5 years ago. He said it started much better and idled much more smoothly. Mine will have it as soon as I recover from the AC install and get my gen put back in after having it out for some extensive repair work. I am just lucky right now and my stock stuff is running flawlessly right now but if it burps I will do it sooner.
Another interesting option is there is a company that is doing the GM style HEI 1 wire hookup distributors fot all sorts of engines now, I spotted someone selling them on EBAY for my 440's for only $100.00, We are going to try one in a buddies Century Saber with a 440 this summer as soon as it is water ready..
440'S 19x22 wheels, 710 HOURS
RiverRatt
#3 Posted : Tuesday, June 01, 2010 4:04:42 AM(UTC)
RiverRatt
I installed Mallory ignition and coil. All the electronics are in the distributor except the coil. No resistor needed if you get the correct coil. Make sure you get a marine distributor that has spark arrestors built in.
If you would like the part numbers I could look it up if you would like.
#4 Posted : Tuesday, June 01, 2010 9:44:19 AM(UTC)
When I switched my small block 327 from points to HEI my tach topped out at only 2000 rpm. I was told I needed a "newer" tach to get correct RPM's from the electronic system.
I just won TWO tach's on E-bay, both with intregrated hour meters. If anyone need the extra tach it is 3 3/8" and available.
jsimanella
#5 Posted : Wednesday, June 02, 2010 2:24:20 PM(UTC)
jsimanella
Spent a good deal of time talking with Jeff on this one...
What I've decided to try is to eliminate the ballast resistor (dual) and switch to a MSD Blaster 12v coils.
There might be a chance that the 5-pin Ignition Modules may not function without the 9 volts provided by the 2nd side of the ballast resistor, so I'm taking 2 new 4-pin units with me, just in case - no start, swap them out too...
This is the last step I have, before I completely replace the Chrysler Ignitions. I think it's got a better-than-fair chance of solving my issues, so it's worth a shot. The upside is that I will gain a better spark, with the 45,000v coil (you can increase the plug gap to .060), and use fewer parts in the process - less to go wrong. And I save about $500 on 2 MSD systems.
I'll keep you guys posted.
PS. On those Mallory units - Were you able to find a counter-rotating unit, or did you have to machine and tweak a standard unit to fit? Or did you need one at all??? Thx.
Raw Water Cooled
jimski2
#6 Posted : Wednesday, June 02, 2010 11:22:20 PM(UTC)
I installed a "Jacobs" high energy system in my old motorhome with a 440 Chrysler. It started as soon as you hit the key and the mileage picked up. The sparkplugs had to be regapped to about .060. Save the old parts as they can be re installed easily in case of the new system failure.
jsimanella
#7 Posted : Monday, June 14, 2010 11:39:09 AM(UTC)
jsimanella
Here's the latest update. Jeff has a diagram that I used to plan my strategy. Maybe he can attach it on this thread...
Replaced the Chrysler boxes with NAPA 4-pin units. $23 each.
http://www.napaonline.co...01+101980+50022+2022024
Replaced the coils with MSD Blaster High Vibration Ignition Coils #8222. Summit Racing. $46 each.
http://www.summitracing.com/parts/MSD-8222/
Had to use a .8 ohm ballast resistor, because I retained the factory ignition system. MSD wanted to use theirs, #8214,
http://www.summitracing.com/parts/MSD-8214/
BUT I OPTED TO USE THE ONE FROM MALLORY INSTEAD, Part #700, because it has post terminals with nuts. A MUCH better connection. They list theirs as a variable resistance of .7 to 1.5 ohms. I have a feeling that MSD's is variable too - they just don't say so. Either way, it's close enough and it looks like better quality. $17 each. I actually got it price-matched at Advance Auto Parts.
http://www.summitracing.com/parts/MAA-700/
Lots of dielectric grease. Especially in the module plug and coil tower! $3 tube.
I removed the 5 pin modules and factory resistors (dual, 4 pin) - some of you only have single 2-pin resistors.
I cut out the 5th wire to the module, since it was no longer going to be used. This wire provided about 9v to the module, though we don't really know why...
I cut out ALL redundant male/female quick disconnect pigtails. Less connections, less problems.
New ballast resistor gets RING terminals (not spades). Better connection.
Check and replace existing coil terminals, as needed - mine were OK.
CHECK THE CABLES AT THE SOLENOID - MY STARBOARD BATTERY CABLE WAS LOOSE :(
Might have been some of the problem, on that engine, but the original COIL WAS LEAKING as well, probably giving me the breaking-up-at-2800rpm issue...
RESISTOR TERMINALS WERE LOOSE, on the original Port ballast resistor. This caused my tach to go nuts, and probably because the engine was cutting in and out. NOT GOOD. This was solved with the ring terminals and new resistors.
All told, I have about $190 Total invested. That's HALF of what it cost me to get pulled and repair 1 prop, damaged from backing into the rocks, when I lost an engine. Cheap insurance, if you ask me, to get rid of a lot of the Chrysler shortcomings.
BTW - During a 2 day, 20 mile round trip, we cruised at about 4000rpm out and 4600rpm back. Not a hiccup whatsoever, and even the tachs were more stable than they've ever been :)
Raw Water Cooled
#8 Posted : Monday, June 14, 2010 1:29:37 PM(UTC)
Gonna try something like this myself. As I discussed with John earlier today, my engines don't like to synch very well: the red LEDs flash constantly, and the green one barely at all. Something is causing the=is non-synch action (that I can also hear clearly). Last year, the green LED came on solid for several miles, and the motors made ONE sound the whole time. (Hasn't done it since, however.) I'm sure that something (like the bad connections John mentioned) is causing a skip in one or both engines and messing up the synch attempts.
#9 Posted : Wednesday, June 23, 2010 11:14:12 AM(UTC)
This will be my big fall project Applause All will be the same for 1985 318's right? Hopefully I will make it until fall with no problems..... d'oh!
jsimanella
#10 Posted : Wednesday, June 23, 2010 6:14:00 PM(UTC)
jsimanella
Everything should be the same. Why wait until Fall? Shouldn't take more than a couple of hours, and you won't have to wait until Spring, to reap the benefits :)
Then again... If it ain't broke...
Raw Water Cooled
#11 Posted : Thursday, June 24, 2010 2:28:47 AM(UTC)
Two hours of summer boating or two hours of work when its too cold outside to enjoy the water? My work list is too long already in the summer. d'oh! Cleaning, general mx, etc. My pleasure hours are worth gold in the summer. Besides we all know, something will need to be worked on every few trips out. Now all I can pray for is that I have no problems with the ignition before this project. Eh?
Brandy
#12 Posted : Thursday, July 08, 2010 9:28:34 AM(UTC)
I have been running this setup and it seems to be fine. I didnt use the balast resistor on the ecm. no problems yet.
Spearo
#13 Posted : Thursday, July 08, 2010 10:48:36 AM(UTC)
That's good to know. The advantage of the resistor is this: If the "Admiral" leaves the ignition on for some reason (you how they do dumb things like that) it won't fry the coil.
Brandy
#14 Posted : Friday, July 09, 2010 12:51:32 PM(UTC)
Spoke too soon! Had problems today, same old bullshit, gets hot, wont start,coils hot , ecm hot , cool down and starts fine. Im done with it. Ordering HEI monday. Someone here found some one wire HEI distriberters for 318s. Whos got the part numbers?
Spearo
jsimanella
#15 Posted : Friday, July 09, 2010 1:11:12 PM(UTC)
jsimanella
Kind of curious, since mine's running better than it ever has - what, exactly, did you try or replace?
Raw Water Cooled
Brandy
#16 Posted : Friday, July 09, 2010 1:36:24 PM(UTC)
Mallory coils , new ecm's, new ballast resistors on coils just in case. I didnt run resistors on the ecm? Maybe thats the problem. From what I can gather the ecm changes votage when it detects startups and such. Maybe without the resistors on them I fried them?
Spearo
Brandy
#17 Posted : Friday, July 09, 2010 1:38:44 PM(UTC)
Call me, I want to talk to you about it 850-255-0498
Spearo
#18 Posted : Thursday, July 29, 2010 8:25:49 AM(UTC)
Hey, what did you guys figure out? No sidebars!! I will be doing this mod this winter... need info
collins69s
#19 Posted : Thursday, July 29, 2010 2:13:47 PM(UTC)
collins69s
Hey Spearo, just thought of this: Mine did the exact same thing you described when my ignition module crapped out.. Heats up etc.. Check your reluctor gap! Check it like compass points North South East West.. Well, none of them are 180 deg. across from each other, but check them... Then put a dial indicator on the shaft and move the shaft back and forth and see how much it moves.. If the bearings in your distributor are shot, you could think the gap is ok, but when it runs the shaft has so much run out it hits the reluctor.. Bet one of the reluctor poles is hitting the pick up! Check your distributor shaft and see if it's bent a bit. Mine is and that's the same symptoms mine was having.. I'm truing it up this weekend.
Hope this helps.
Sean
SIFF SURF
1972 32' FB Express
Dr Gonzo
#20 Posted : Monday, August 30, 2010 1:07:40 PM(UTC)
Im going with a brand new MSD setup on my rebuilt 440's. Distributors, 6a box's and coils. much better fuel economy.
2 Pages12>
This page was generated in 0.396 seconds.
