New Engine Gauges?
ThanksDad
#1 Posted : Tuesday, December 18, 2007 5:10:31 AM(UTC)
ThanksDad
My 20 year old gauges are starting to show some signs of age.
- Port tac bounces +/-500 rpm quite often. All connections seem to be tight. I have been using the starboard tac and engine sync.
- Starboard oil pressure sticks at 40psi after you shut down.
- Starboard ammeter sticks on start-up.
- Fuel gauges...who knows?...I use engine time x fuel burn (Old pilot habits die hard).
- All gauges seem to work better the more the boat is run. We all know, lack of use causes problems!
Questions:
- Should I bite the bullet and replace all gauges at once. Both tacs, oil pressure, ammeters, water temp (not fuel).
- How do I determine if it is the gauge or sending unit. I am 80% guessing it is the gauges and not sending units?
- Is this a do-able DIY project or should I leave this up to my mechanics who are very good and very fair priced.
- If/when replacing should I try to go with as close a Teleflex replacement part as possible?
- If I go with total replacement, what would be a good ballpark cost
Any thoughts would be quite helpful. Any way to save a buck would be great too!
Thanks, Scott
Scott Ross
"Thanks Dad"
1988 32-Fisherman
Son Rise Marina
Sandusky, Ohio
USCG 50-Ton Masters Rating
#2 Posted : Tuesday, December 18, 2007 6:05:45 AM(UTC)
Scott:
Swap the leads from the port guage to the starboard guage to narrow the source of the problem. If the "problem" moves over to the other guage, it's the sender or wire lead that's the source. If the problem stays at the same guage it's the guage or ground to that guage.
#3 Posted : Tuesday, December 18, 2007 8:57:26 AM(UTC)
Hey, Newbie, I'll bet those are all flybridge gages, right? Nasty environment up there. You might save yourself a ton of trouble by "simply" replacing them all over the winter.
If I had to do that (thank God no!) I would disconnect and label every wire where the wiring joins the terminal strip. Then, I would remove the entire gage panel, photograph the hell out of it, label the hell out of it, then proceed to replace one gage at a time. That way, you might avoid an Ah Sh*t! moment or three.
Good luck!
#4 Posted : Tuesday, December 18, 2007 10:07:22 AM(UTC)
SCott: fyi - I have checked this far on one of items you raised: Teleflex no longer makes the face design you probably have in your boat (same vintage as mine), so you won't be able to match zackly. The new ones are same size, same functions. I also have kerflooey gauges: the stbd voltmeter on the bridge sticks and I have to whack it with my knuckles (ouch!) and it works fine til shutdown. And the tachs bounce also but not as much as yours. Except sometimes.
I'd replace one gauge at a time, wire for wire. And as Jeff suggests, take a picture in case you get interrupted to pee.
#5 Posted : Wednesday, December 19, 2007 2:49:18 AM(UTC)
Scott
Don't forget to disconnect the battery or sparks will fly.
"ALUMINATION"
Grosse MI - FYC
#6 Posted : Wednesday, December 19, 2007 4:35:43 AM(UTC)
I have excellent stainless liquid-filled vacuum gauges for my fuel filter inlets from www.surpluscenter.com. They also carry cheap automotive gauges.
www.fpmarine.com has a warehouse full of gauges but it is better to pick your own, although you can order from them online. They will dicker.
www.surplusunlimited.com in Daytona also has a lot of marine gauges at so-so prices.
There are gauges at greatlakesskipper.com but I have not purchased from them.
While you have the wires off, solder on new terminals if you are in salt water. Might save a lot of trouble later.
marinettejoe
#7 Posted : Wednesday, December 19, 2007 11:45:23 AM(UTC)
marinettejoe
Check the voltage at the gauges and see if the Chrysler Voltage regulator is bad. (Well actually they never worked very well.) In the early days, They made a bimetallic thing-a-ma-bob that should be replaced (1960's?) when it goes bad with the newer electronic one. Someone had a circuit for an electronic regulator to replace the Chrysler, (no fluttery gauges). Lost the link.
Third party regulators do a much better job. will check around.
#8 Posted : Wednesday, December 19, 2007 9:32:10 PM(UTC)
To All,
A good way to fix a gauge problem is to tighten up on the wire connecting lugs even if U get a 1/8 turn. An even better way but some what tedious is to clean the wire connecters with a fine piece of say 200 grit emery paper if the gauge is not bad in itself this method will eliminate the fluctuations in them. On any of the ignition wires or switches pay particular attention to the violet wire. Over the years the wire connecters get a greyish white film on them ever so slight by
cleaning this off it cures the problem. I damn near threw 2 perfectly good F/B Tachs away till a fellow boat showed me this little trick. I usually go through this chore on days when the weather is inclement by doing 1 or 2 gauges at a time, of course don’t forget to turn the Power OFF
AnyWho it worked for me. Whistle
Norm, Brick wall
#9 Posted : Thursday, December 20, 2007 3:10:42 AM(UTC)
Sounds like this is good advice for both ends of the connection; the gauge and the source/sender,
ThanksDad
#10 Posted : Thursday, December 20, 2007 5:06:47 AM(UTC)
ThanksDad
Thanks for all the great replies. I think I will start with really cleaning the connectors. It sounds like a good wintertime project. If that cures it, then more money for the fuel tank next summer!
Scott Ross
"Thanks Dad"
1988 32-Fisherman
Son Rise Marina
Sandusky, Ohio
#11 Posted : Friday, December 21, 2007 2:16:24 PM(UTC)
We both have a similar problem. My project 32' sat out for years and the flybridge gauge set took a beating from the elements. The inside console gauges all worked perfectly and the wiring looked new. The gas senders were shot. I pulled the flybridge gauge wiring harness out in mostly one piece. It's on the bench waiting to be reconditioned. I would never pull the inside wiring harness - work on it in place. I downloaded a bunch of stuff about gauges from the Teleflex web site. I went back there to look for the links so I could give them to you. They reworked the website and they removed the search function so I couldn't find the links. I sent a message to complain and they promptly responded with a .PDF on testing gauges which I will attach to a message as soon as I figure out how. There are other good Teleflex writeups such as "Marine Fuel System", "oil pressure systems", "voltmeters", "temperature systems". there If you pester them at www.tflx.com they may send you the PDF's. Meanwhile I will look for mine. We should build a document repository on this forum for this stuff. The only gauges I have not discovered how to bench test are tachometers. Still looking.
I did find this newer stuff but but it has less information in more languages.
http://www.teleflexmarin...ype=us&library=1019
I am also looking for the perfect chemical cleaner for the terminal connections. There are hundreds of oxidized connections on my flybridge harness. Some I will replace but I don't want to detach clean and re-attach each one. There is also the whole solder vs. crimp thing. This is kind of a religous issue. Doug Rose may weigh on on solder. I bought aircraft quality insulated double crimp connectors and a matching ratcheting crimper. They don't use solder on most aircraft and they sure didn't on Marinettes.
If you need new senders let us know. There are members here that know where to get the right New Old Stock (NOS). Note dual station and single station senders may differ.
marinettejoe
#12 Posted : Saturday, December 22, 2007 6:31:29 AM(UTC)
marinettejoe
Tachs run off a pulse stream. Here is a quick test using a serial port.
http://www.turbocontrol..../computer_tachometer.htm
#13 Posted : Saturday, December 22, 2007 10:35:22 AM(UTC)
I don't mean to get into a discussion of crimp vs. solder, obviously crimp works fine in lots of hi-tech applications. I just think solder is better when just a few wires are being terminated.
I haven't tried this: I use a solder pot for my terminals. I just crimp lightly, flux, and then hold the wire and dip the whole terminal into the solder -- until there is good flow up the wire. So, perhaps old terminals could be 'refurbished' by the same method, and then dressed up with a little tape or shrink tubing. It would be a lot faster than what I have done. I replaced most of the cables entire, but they were terrible, being in the World's Worst Corrosion Environment (tm). The original factory wiring was pretty good when new, and must still be OK in fresh water.
I use electronic senders from Centroid Products. They work very well, and one is 15+ years old.
Capt T
#14 Posted : Sunday, December 23, 2007 4:15:47 AM(UTC)
Capt T
Also http://www.teecoproducts.com/Catalog/N7.htm sells Rochester Gauges. Note that Old Twinsites cannot replace the non sending dials. www.rochestergauges.com
Posted by Joe
1978 Aft Cabin
Twin Chrysler 440's
Fox Road Marina
#15 Posted : Wednesday, December 26, 2007 3:50:17 PM(UTC)
I ordered $57 worth of Deoxit connector cleaner to work on my flybridge gauge wiring harness. It's expensive but my homemade acid solutions didn't work well. I'll let you know how it goes. I'm setting up the test bench now.
marinettejoe
#16 Posted : Friday, December 28, 2007 7:08:03 AM(UTC)
marinettejoe
Here is a great old article on Gauges from the allpar group. Very few marine chrylsers will have the bimetallic regulator. :d/
http://www.allpar.com/hi.../mopar/electrical2.html
#17 Posted : Tuesday, February 08, 2011 6:45:14 AM(UTC)
I have put some information on Marinette gauges on my website at http://web.me.com/dougmr...ses_Website/Gauges.html
Perhaps it will be a useful reference for someone.....
#18 Posted : Wednesday, February 09, 2011 2:59:31 AM(UTC)
Like I said my flybridge gauges on the 32' project boat took a beating from the elements. I mounted them in cutouts on a sheet of 1/4 plywood in the same arrangement as they mount on the fly bridge. The flybridge was sent out for painting. I cleaned out the dirt and cleaned up the contacts. Used a 12 volt power supply for benchwork. When you look at the back of the gauge and switch panel it looks complicated. It is not. Gauge wiring is simple. Lighting wiring is simple. Mix them all together at it looks like a birds nest.
I did not try and undo each frozen connection. I tested each and cleaned them with a product called Deoxit. I tried some much cheaper acid mixtures followed by baking soda. That did not work. After a few days the copper bloomed out green. Biggest problem was busted breaker switches. The barrels that fit through the panel break off. Stuff that looked real bad still works. I would like to find new ignition switches. They bench test but they look bad. I would like direct replacements. I still have no way to load test breakers or test/calibrate the tachometers on the bench. Anyway it all goes back together early this spring.
Jack Marchand
#19 Posted : Wednesday, February 09, 2011 4:47:37 AM(UTC)
Jack Marchand
Electricians use a compound called noalox between conections that have aluminum AND copper present (as in the junction of two dissimilar metals) to keep oxidation in check. It is an antioxident and is very easy to use, simply wipe it on any CLEAN connection and wipe off any excess to get an oxidation free joint. I have used this product for years and is required by the code to stop oxidation between copper and aluminum. I have not used it in the marine envirnment as yet, but I see no reason it could not be used. It is made by Ideal and is readily available at any home depot or lowes for about 4 bucks for a small tube. If anyone has used this product on this level, let us know. JAM
This page was generated in 0.323 seconds.
