HOW TO INSTALL A BOW EYE
I wanted to be able to reach it so I laid down on the deck, and reaching as far down as possible, marked the spot. Then a measurement from the deck plate was transferred into the anchor rode locker to make sure the location would work.
Drilled two 1/16 holes at the correct spacing and gradually increased drill bit size up to the 1/2. The sharp V of the bow had to be hand filed to get the nuts to seat right.
The hardest part was cutting the bevel on the bar stock with a Sawzall. 4200 sealer was applied to the outer nut seat and U bolt threads. Stainless washers and lock nuts secured the deal.
Got the
SS U bolt (5/16" X 3 1/8") from West Marine and the aluminum bar (2"W X 5"L X 3/4"H) from the scrap yard.
Check out the pictures
here.
Specs:
