The important thing here is to LISTEN to the engine as you attempt to start it after letting it sit overnight (or longer). If it sounds like (this on the starter), RRRRRRRRR, you're okay; light her up. But if it does this, RRRR-hesitate-RRRR--hesitate, then do NOT try to start it! There's water in a cylinder and, since water doesn't like to compress, you can blow a head gasket, bend a rod, blow a piston or even blow the head off the motor!
Two full revolutions of the motor is all you need.
Note: If your motor is one that fires instantly you'll need to install a "bump" circuit to wheel it over without allowing it to start. I shudder to think of those new EFI motors that fire at the turn of the key!
PS: You folks that only run your boat from the flybridge need to be especially careful on first start up since you can't hear as well as us "lower helm runners."
