First CAN project using Keil uVision (Updates in the text).
marinettejoe
#1 Posted : Wednesday, January 02, 2008 8:19:22 AM(UTC)
marinettejoe
Code is zipped here.
Program uses the Luminary Micro LM3S8962 board with the evaluation keil compiler and the 2110 board.
The evaluation kit is available from Digikey for $79
Accepts 2 can messages from the board and displays either CAN 1 or CAN 2 depending on which button is pressed.
So far 5536 bytes of the 20K.
NMEACan1.zip (182kb) downloaded 146 time(s).
marinettejoe
#2 Posted : Wednesday, January 02, 2008 8:31:30 AM(UTC)
marinettejoe
What's next.... I plan to set up the filter on the device to accept (read only) filtered messages (either J1939 or NMEA 2000). Something simple.
Barely readable is the CAN 2 message from pressing the #2 button on the 2110 board.
The 8962 data sheet is 1/2 way down the page.
http://www.luminarymicro...m/home/data_sheets.html
marinettejoe attached the following image(s):
marinettejoe attached the following image(s): 010_0504.jpg
marinettejoe attached the following image(s): 010_0507.jpg
marinettejoe
#3 Posted : Wednesday, January 02, 2008 5:22:28 PM(UTC)
marinettejoe
http://www.luminarymicro...net_evaluation_kit.html I am using the EKK evaluation copy limited to 20K .
I have the Code Sourcery also, but am finding Keil a lot easier. The kit is $79 bucks from Digikey.
marinettejoe
#4 Posted : Thursday, January 03, 2008 7:03:24 AM(UTC)
marinettejoe
Still gutting it from a sample project... Keeping something working... So far 20 hours invested.
marinettejoe
#5 Posted : Thursday, January 03, 2008 7:10:40 AM(UTC)
marinettejoe
Have decided on the first project requirements. The project will read (only) all can messages and output them to serial/usb. Every 100 ticks or so Both engine Tachometers will be displayed.
Should be simple enough.
marinettejoe
#6 Posted : Saturday, January 05, 2008 2:07:21 AM(UTC)
marinettejoe
I will not be posting those can /NMEA 2000 messages to the serial bus, but will write them to the microSD and a webservice.
Luminary Micro's 8962 kit is great. I have a sprintf memory leak... Time to use snprintf and get the C book out. Really wish I could use Bounds checker on ARM.
Those using new OBDII kits (Elmscan 5) will note that there is a can diagnostic kit. I may pick one up to hack it for NMEA2000.
marinettejoe
#7 Posted : Sunday, January 06, 2008 7:47:13 AM(UTC)
marinettejoe
Here is NMEACAN2.zip.
Fixed the leak in snprintf. I needed to allocate heap of 200 bytes and 500 bytes to the stack) for stdio library calls. Idiot!!! standard lib calls need heap and stack memory. Sheesh. Brick wall
Currently the code is just CAN message handling from button press and is not much more than the LM code. I need to revise it for NMEA 2000 messages, so more protocol work and decoding. This seems to be the only NMEA2000 hobby project in process on the net.
It's design will be to collect CAN messages and allocate them to by PGN handler code as a dispatcher. Most messages will be ignored by the filter.
So far just about 30 hours invested. Faster than I expected.
The blurry pic reads
Hello World! Joe
Canx00000010 (Msg ID)
with Data Byte1 x01 (pressed can button 1).
This is 250K rate. The LM board is very nice.
NMEACAN2.zip (224kb) downloaded 134 time(s).
marinettejoe attached the following image(s): 100_0525.jpg
marinettejoe
#8 Posted : Sunday, January 13, 2008 5:25:10 AM(UTC)
marinettejoe
Good paper on the address claim process URL http://www.agen.okstate....papers/Dynadr/dynadr.htm
marinettejoe
#9 Posted : Saturday, April 26, 2008 1:32:02 AM(UTC)
marinettejoe
Status Still waiting on parts from wesgarde and an optoisolator from digikey.
I want to get the boat back, install the Maretron Fuel sender and the finish the kvaser test harness, to finish this out.
marinettejoe
#10 Posted : Tuesday, May 13, 2008 2:53:58 PM(UTC)
marinettejoe
And still waiting. Was promised this on the 25th and is was supposedly sent out.
marinettejoe
#11 Posted : Monday, June 16, 2008 11:56:59 AM(UTC)
marinettejoe
The parts are in.... Wesgarde came through.... Just need time to finish it.
This page was generated in 0.911 seconds.
