IMRON
sfordsr
#1 Posted : Tuesday, April 29, 2008 11:12:54 PM(UTC)
Anyone have an idea how long an IMRON paint finish will last? Or at least look good?
#2 Posted : Tuesday, April 29, 2008 11:29:22 PM(UTC)
Depends
If the prep work is done correctly 10 to 15 years. longer if shed kept.
7/8 the cost is correct prep. Skimp on PREPERATION and your looking at a mess in two years.
Just my $.02's
"ALUMINATION"
Grosse MI - FYC
#4 Posted : Wednesday, April 30, 2008 12:07:47 AM(UTC)
Contrary to what most will say, keep it waxed every year after the paint job and it will last years. A good wax is the key to keep any paint from oxidizing.
As mentioned earlier, prep is also key. Prep is 90% of the paint job.
There is a place by me that preps by removing everything down to the AL and even removes and replaces the fairing/bondo.
Some paints don't work well with bondo particularly the older stuff Marinette used. The new paint will begin to lift at the fairing seams.
I've seen a beautiful Marinette painted with PPG paint. It is waxed every year and looks like it was dipped in glass. Its been more than a few years since it has been painted. Just amazing how good it looks.
#3 Posted : Wednesday, April 30, 2008 4:08:56 AM(UTC)
Bill wrote:
Depends if the prep work is done correctly 10 to 15 years. longer if shed kept. 7/8 the cost is correct prep. Skimp on PREPERATION and your looking at a mess in two years.Bill
Bill is spot on correct. My boat was done in Awgrip in 1999 (at a rather large cash outlay, I might add) and a couple of years later, some areas began to flake. I know that it was completely due to poor prep - leaving bare aluminum exposed way too long before coating. Now, 9 years later, other corrosion points, primarily the notorious points under the rails, are also beginning to show paint lift bubbles. I try never to look down because I will see only dollar signs along that area.
#5 Posted : Thursday, May 01, 2008 4:03:38 AM(UTC)
I have seen Imron/Awlgrip put directly over existing surfaces. I do not believe that this is a good idea. Use a 2-part epoxy primer, perhaps a high-build primer that can be sanded, and put the top coat on the primer. This is because epoxy sticks to most anything, polyurethanes don't.
I once had a guy paint his go-fast boat in my shop. Took days to tape off the graphics. Then the Man With The Golden Arm came in and did a beautiful spray job in bright yellow on the whole boat. Next morning, the paint was all in little globules with bare spots between, and hard as a rock. They sanded it down, retaped, and reshot over epoxy primer, as had been suggested. Beautiful job, but two weeks wasted and you can still see little "coins" in the finish where the globules were.
#6 Posted : Thursday, May 01, 2008 5:09:23 AM(UTC)
Polyurethane PRIMER sticks to anything, and other paints stick to it well. It's easier to use than epoxy, and sands beatuiful. When repairing f-glass molds, I found that priming the f-glass with urethane primer produced a better bond than resin on resin!
Jeff (the Man with the Tin Hand)
#7 Posted : Thursday, May 01, 2008 5:20:38 AM(UTC)
I've always used the high-build epoxy primer because it sands so well and can cover a really BAD surface, and also because I've always used the high-build epoxy primer. Perhaps I should try polyurethane primer. Is there a sandable one you can recommend? Don't rush, I have several gallons of the epoxy I haven't used yet, and I am not using it up very fast sitting here in DC....
#8 Posted : Thursday, May 01, 2008 10:58:11 PM(UTC)
All of them are easily sandable, and they too are high build. They've been the staple of body shops for some time.
#9 Posted : Friday, May 02, 2008 2:26:18 AM(UTC)
"...for some time."
I haven't done any body work for 40 years. I guess I need to get out more.
This page was generated in 0.172 seconds.
