Curtains - HELP! Options · View
pastelblack
Posted: Monday, June 16, 2008 9:28:17 AM
Hi All - I was getting ready to buy and install brand new curtains and a hanging system in my 26 convertible and have discovered this is not as cut and dry as it appears. Can anyone offer some advice, recommendations, suppliers, tips?? Two areas that seem like they may be a bear to deal with are the two huge front windows. Also, on the side windows near the front the lower side of the window is longer than the top.......yet another issue (i.e. how to cover that lower triangle that would seem to be exposedsince the top track will end short of the total bottom window edge....am I making any sense??)....any ideas on how to handle that would be very welcome. Also, I'd love to see some photos of what you guys have done if possible.
Thank you all for all the great help with the boat......
Bob
Posted: Monday, June 16, 2008 9:41:15 AM
The little metal track from the factory that supported the curtains via small plastic balls that fit in the track is excellent, but I could not find any of the track, and most of mine was missing.
My curtains were folded over and sewn at the top and bottom so that a dowel could be inserted, and the dowels were set over little brass hooks screwed into the wooden trim. I don't recommend this, the dowels warp and if someone grabs a curtain and pulls, the dowel breaks.
I used 5/16" shock cord (black looks good) instead of the dowels, stretched tight above the windows. This stays straight, looks good, and if someone tugs on it, it will snap back again.
For the windshields, I use reflectix fastened with velcro, because a lot of heat will come in there, especially in Florida.
Posted: Monday, June 16, 2008 10:59:44 AM
I went through the curtain making process. All of the curtains on my project 1988 32' were gone except the plastic ones in the bathroon. Fortunately all of the tracks were still in place. www.Sailrite.com has all of the things you may need for an 1980's Marinette. The system consisted of tracks that hold the ball of little plastic tabs to which the curtain is hung. A line of tabs comes on a fabric ribbon which is sewn across the top of the curtains. You thread these into the tracks. Little screws plug the end of the tracks. The front window problem is solved simply. A track is screwed to the top and botton of the window frame and the curtain is stretched between them. You need some reinforcing fabric tape which is like the tab ribbon but without the tabs. Use this along the top of the angle where a bottom of the curtain is longer than the top. The bottom of this curtain will have a fabric snap to attach to the wall. In fact, you should see attaching points for fabric snaps all around the cabin walls. These were used for curtain holdbacks. They give you an idea of how many curtains were used and how they were laid out.
The project starts with detective work. Look for clues like original track, the tabs and the snap locations to guide your design. If all this is tore out then you can use the sailrite catalog to start from scratch. Make a detailed graph paper drawing of the window areas with careful measurements of the track locations and lengths. Take a complete panoramic set of pictures of all of the window areas. Note impediments on the drawing. My fire extinguisher was in the way of the long curtain on the back of the salon. The inside helm cabinet got in the way of my port side window curtain. Be thorough so the curtains can be made away from the boat.
Now you need the help of a good seamstress. Mine was a generalist not a boat specialist. I bought my fabric locally and I opted for a lot less pleating than on pictures of the original Marinette curtains. I also went with unlined curtains so they were pretty simple. The seamstress was good and fast and had no trouble. She did go to the boat a couple of times for final fittings. She even threw in a couple of matching throw pillows. I challenged her and she may do the skirts on my outside railings. She turned down putting covers on my V-berth cushions. So I may challenge her again.
Marinette made some special curtains out of white plastic sheeting to protect the bathroom cabinets and window area from shower spray. These helped me because they survived and showed the basic construction of the curtain. I also found one surviving holdback which was used as a pattern to make one for each curtain. I may dig out some stuff and attach a picture here later. My curtain stuff is all packed away waiting for me to finish the rest of my boat. This should get you started.
Posted: Monday, June 16, 2008 11:32:32 AM
"...on the side windows near the front the lower side of the window is longer than the top.......yet another issue (i.e. how to cover that lower triangle that would seem to be exposed since the top track will end short of the total bottom window edge....any ideas on how to handle that would be very welcome...."
On my boat, the lower, longer edge was fastened to the wooden trim with metal snaps. An easier way to handle this would be with velcro. Only problem here is that the velcro might not want to stick for long to the oiled wood. Solve that by tacking or stapling it into place.
Making curtains should be quite easy for a competent seamstress since you are dealing with straight lines. They should be a bit longer than the tracks to give you an attractive pleat (but as was already pointed out, not as long as the original curtains which gae way too much pleat). I put a little heavier liner on the curtains to ward off the sun. I think the material (sorry, can't recall the brand/make/etc) sheds water better. It may be in the Sailrite catalog along with all the other supplies you need.
My job was an easy one since we used the old curtains for a pattern (but the careful seamstress measured anyway to be certain).
"Charlie B" - 32' FBS
dependo
Posted: Monday, June 16, 2008 11:40:11 AM
Bob, when I did my express I did what others members had done and ordered mini blinds the size of the windows. the tringle area I used A product from Lowes that is vinel and sticks to the inside of the window and makes it look frosted. Used it in the head & in the small window in the cabin door. my front window I have a white vinel cover that snaps on the outside. With blinds you can open them & let more air in. If you run fast with the windows open, you will have to raise the blinds because they will make a racket as the wind goes thru. I will try to send phots. Wayne, redneck from Tennessee
Domino
Posted: Monday, June 16, 2008 12:31:59 PM
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/3828/377%20710/0/curtain%20tracks/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=curtain%20tracks&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=curtain%20tracks&isLTokenURL=true&storeNum=5004&subdeptNum=15&classNum=480
check out the link above at West Marine for info on the RECMAR PRODUCTS
Port Curtain Snap Track System. I used on my 1967 32'.
I was lucky enough to have my old curtains to use as a pattern for my new curtains. Just took my old curtains to my canvas guy and he did the rest.
The old track system was interchangable with the new RECMAR system so I just replaced it all.
Good luck!
Al
walt2007
Posted: Monday, June 16, 2008 12:33:22 PM
Rank: Member
Along this same line, has anyone had any success with a screen for the front awning windows? We have been trying to figure out something that is permanent and can be opened and closed. The hold open arms seem to be the biggest impediment. We hate to close these windows at night (but not as much as we hate those mosquitoes).
Domino
Posted: Monday, June 16, 2008 1:32:57 PM
How about flexible fiberglass screens and velcro?
Al
Posted: Tuesday, June 17, 2008 7:32:54 AM
Walt,
I tried all kinds of stuff -- velcro, shock cord, you name it -- for the windshield and finally settled on making folding screens using the aluminum stock that they sell for window screens along with the plastic corner hardware. I used plastic hinge fastened with permanent management tape but if I did it over I would use aluminum piano hinge and poprivet it in place.
I made two sets, a small one that doesn't leak in any weather and a large one to capture as much breeze as possible.
You can see pictures and dimensions at http://s101.photobucket.com/albums/m41/dougrose1/Marinette_screens/
I guess if Atlanta draws any more water from Lake Lanier you will need to put wheels under her and go mud bogging. Will still need the screens, tho.
dacroof2
Posted: Tuesday, June 17, 2008 8:00:22 AM
Groups: Member , Other Mods
If you can find some one to make the curtains that is the way to go. my wife used the old ones as patterns.
You can get all the hangers and curtain hardware from sima marine in eastlake, ohio 440-269-3200
www.simamarine.com
walt2007
Posted: Tuesday, June 17, 2008 11:14:29 AM
Rank: Member
Thanks Doug. I think that is the solution I was looking for. As for the water level, your correct. We have been back in the water for 4 weeks now and are already faced with the prospect of relocating to a new marina or taking the boat out again. Really hurting the marinas and all boat related businesses in the area.
Thanks again for the screen help.
Goldpoint
Posted: Saturday, June 21, 2008 2:36:02 AM
Time to catch up after business travel this past week. I don't care what they say about 'dry heat', 106 to 112 degrees in Arizona is HOT.
We did new curtains a few months ago. Used the handy dandy "Marinette Parts Sources" post here on the site and bought the sew on tab material from Sailmaker's Supply http://www.sailmakerssupply.com/prod_detail_list/20 . Noticed they are more expensive on the tape than Sailrite, but the tracks were a bit cheaper.
Wifey found some 'cheap' curtain material at Windowtopper's - http://store.windowtoppers.com/280tiers24.html . The 24" length is just about perfect. Sew on the tape, cut the angle on the bow end and hem it, add a few snaps and it's a done deal. The front windows in the cabin require hemming the panels to a shorter length, but she didn't seem to have too much of an issue with it.
A picture...
Goldpoint attached the following image(s):
bruegf
Posted: Monday, June 23, 2008 5:14:14 AM
Rank: Advanced Member
norbie
Posted: Monday, June 23, 2008 7:19:17 AM
A lady in West Palm Beach took my old curtains
from my 32 and mirror imaged them perfectly.
Domino
Posted: Monday, June 23, 2008 8:54:17 AM
Goldpoint, what a low cost solution to the new curtians problem. And they look great!
Good job! Nice to have a wife that sews!
Al
Goldpoint
Posted: Monday, June 23, 2008 3:45:42 PM
She is a jewel! That is why I named the boat after her.
Goldpoint
dacroof2
Posted: Monday, June 23, 2008 6:32:36 PM
I noticed that the curtains are a single ply. For a darker and cooler cabin its nice to have a second panel sewn to the outer for those afternoon naps. Just a thought. Dean
Guest2
Main Forum RSS : RSS
This page was generated in 0.643 seconds.
