clarko wrote:
I have been following the electrolisis thread for the past couple of days and wanted to add something. There was nowhere that an "add reply" was apparent. Is there a limit as to the thread length before it is shut off? When I went to another thread there was an "add reply" on it. In any case since I couldn"t add a reply on the electrolisis thread, I am trying and end run.
Clark: I think I have figured out what happened here. Just a guess - but I think I'm on the right track.
The thread got into a bit of a p***ing match over whether a vendor had posting and discussion privileges and Joe, our moderator, indicated "end of thread" in the last post to, I think, cut off the debate. Just now, using deputy admin privilege, I unlocked the thread for a moment and all the posting/editing/quoting options reappeared. I re-locked and these options again disappeared. Giving way to Joe's superior rank as the heavy-lifter here and the Honored Fellow who set up the site at a great investment of personal time, I am leaving it locked.
Your "end run" was ok because you shifted the discussion a bit and a new thread is in order.
Meanwhile, there's another isolation test. It takes two people. One holds in the Capac meter button to check if the meter deflects when the other runs a probe between the shaft and that bare spot on the hull.
the info comes from an earlier post here in this Electrical & Corrosion section:
PROPELLER SHAFT GROUNDING - Problem: Propeller shaft is improperly grounded to engine or hull. To determine if this is the cause, ground shaft to hull. This can be done with screw driver by touching bottom of hull with point and the shaft with the side of blade. Do this in the area between stuffing box and coupling. If the shaft is not grounded, the meter will deflect downward indicating proper installation. If a grounded condition still exists, disconnect propeller shaft coupling from the engine. If the coupling was grounded to engine, then needle should deflect upwards on the scale when this separation occurs.
"Charlie B" - 32' FBS
