From Mrs. Fastjeff Options · View
Posted: Saturday, May 31, 2008 6:38:05 AM
Hello!
I have been wondering if any of the other Marinette '32 wives have some suggestions - minus the frustration - for keeping the bottom sheet tucked in the V-berth and not be able to come out during use. Clips and foam rolls as used in sofa slipcovers have been to no avail. Many thanks in advance for the help.
Millie
dacroof2
Posted: Saturday, May 31, 2008 9:38:11 AM
Groups: Member , Other Mods
(bosun whistle) attention all hands...admiral millie fastjeff has boarded the forum. make way, stand clear, all hands to quarters.
the best thing to do with those v-bunk cushions is to pull out the old sewing machine and custom make fitted sheets with elastic strapping below. attach flat strapping on the edges and have velcro across the other side to hold the edges from creeping up. If you toss and turn even that won't keep them from riding up. now we throw the kids under there and we sleep on the setee or dinette where I think its more comfy anyway.
Posted: Saturday, May 31, 2008 1:02:59 PM
Thanks. She'll be getting back to you. (Don't forget to duck!)
Mr. Fastjeff
Goldpoint
Posted: Saturday, May 31, 2008 5:22:05 PM
We were taking dimensions this morning for this very issue. Wifey said the only way she was going to be happy was to customize some sheets to fit the cushions. Hope it works!
John B.
MHYZHEN
Posted: Saturday, May 31, 2008 6:42:42 PM
Heres an interesting little winter project i found.......anyone up for the challenge ?
I would NOT call this job hard to do, in fact it's really kind of simple in a boring way. The mattress springs look very intimidating when you first get inside the mattress but upon closer examination, it's really very simple construction. The spring removal and position adjustment was pretty simple. I had to remove springs that were originally on or over a diagonal line to create a mattress that looks like a potato wedge. I am using 2 twin mattresses side by side, both have one side cut on a diagonal to form the "V" of our forward berth. This means some springs get moved a little "on top" of their neighbor spring while other springs move "farther away" from their neighbor springs. This movement of the springs is so the edge steel rod (almost) always has a spring attached to it to support it. I did a pretty good job moving the springs and when you remember you don't usually sleep on the edge, there is no effect on comfort that My wife or I can detect.
http://theboaters.com/boats/Powerboat/Classic_/_Antique/Marinette/express/1964/MHYZHEN
One more busted knuckle and i'll have a complete set !
MHYZHEN
Posted: Saturday, May 31, 2008 6:46:36 PM
heres the matress.........
MHYZHEN
Posted: Saturday, May 31, 2008 6:49:08 PM
and heres what a a couple hours can acomplish on the weekend.......
Remove the edge seam binding tape, don't cut it off just remove it from the quilted top and the bottom and let it hang. I used a box cutter blade and slowly worked my way down one side. Don’t destroy the seam edge tape, you will need to re-sew it back on later.
Next remove the metal rings that hold the top and the bottom of the mattress padding to the metal spring base. They are soft metal rings and easy to unbend. The upper and lower material that these steal rings clamp on to the metal frame, seem to be a “Tyvek” type material. So that’s what I used to sew back on the mattress topper. I used plastic wire ties to reattach it to the metal frame. That will be shown later.
These are the springs I removed. I tied a string to mark the outline of the finished angle of the mattress. I used some wire cutters to cut his excess group of springs away. The little pig tail springs you can see, hold each support spring in place,. They are not as tough as you might expect. My needle nose pliers cut through them easily and you can bend this spring shaped steel. It is not tempered like a “spring” but rather it’s more like strong wire shaped like a spring. I made sure that each “cut end” was bent to point away from the top or bottom fabric. I didn’t want any if this metal poking through so I was very careful.
I have removed a large section of the springs that roughly conforms to the new mattress shape. Notice the stair step nature of the cut? It is this stair step edge that must be smoothed to generally reflect the straight-line diagonal of the wedge shape mattress. We have to unwind these edge springs from their "pig tail" wire holders, move them to their new position, rewind the "pig tail" wire to hold them in place.
Notice also the upper and lower steel rods remaining in the original rectangle shape. These rods will have to be cut, reconnected together, bent to the new wedge shape and reconnected before we can then reattach the springs.
These tools served me pretty well. The surprise tool is a pair of pliers used for attaching “F” connectors on the end of coax cable. This pair of pliers was just the right size to reattach the clips that hold the springs to the steel edge rods. Needle nose pliers, side wire cutters, 2 lineman pliers were all the pliers I used. Bolt cutters to cut the extra steel edge rod, the removed (extra) section is also shown.
Pipe wrenches used side-by-side make effective rod benders. I was able to bend the rods exactly as I needed with out stressing any other part of the mattress.
MHYZHEN
Posted: Saturday, May 31, 2008 6:51:06 PM
This photo shows the top half of the springs attached to the newly formed steel rod edging. Notice the springs in positions 1-8
Spring 1 is on top of its neighbor in the 12:00 o'clock position.
Spring 2 is right next to the spring at the 12:00 o'clock position.
Spring 3 has what looks like 1 inch to 1 ½ of space from it’s12:00 o'clock neighbor.
Spring 4 looks like 2” away from it’s 12:00 neighbor.
Springs 5,6,7,8 repeat the positions of springs 1234.
This readjustment of the edge springs, smoothes out the stair step edge we got from the cutting away of extra springs.
The springs were reattached to the steel rod edging with the original metal clips using the “F” connector pliers.
Do the same thing to the upper steel rod edging.
I didn't say anything about those tough wire "pig tails" They are no real problem, you just unwind them and rewind them onto the springs you want to move. Now "unwind" is not "untwist" the pig tail springs. To wind them you just place your mattress spring top ring between the pig tail coils and wind the pig tail spring around the mattress spring. It's easy BUT the "pig tail" can't be too long so trim them to just the length you need before you begin to wind. Wind 3 times around every mattress spring. CAUTION when you cut the pig tails you will create a sharp edge. These edges will cut your hands so be careful.
This photograph shows how easy it is to attach 2 springs together. Just wind a piece of pig tail wire at the junction of two springs. You cut a piece of wire and just like turning a bolt onto a screw, screw the wire over the spot where you want to join the springs. Bend down the sharp edge and you're done!
Cutting the steel edge rod requires you to join it together again. I considered several options including welding but each had it’s own disadvantages. My solution was to get a piece of 1/4 “ O.D. refrigeration grade, copper tubing. I found this at Home Depot. The interior dimension of the tubing fit the steel edge rod perfectly.
So I cut a small piece, mixed up some epoxy, slipped it over the cut rod and let the epoxy do the rest. It’s easy, clean and works great.
This photo shows the "F" connector pliers and the small clips that hold the springs to the edge rod.
Here is a photograph of me using the F connector pliers to compress the metal clip that holds the spring onto the steel edge rod.
I used 2 pipe wrenches to bend the steel edge rod. I was easy to do, and placed no stress on the rest of the mattress.
This photo shows us trimming away the excess mattress material.
This shows the simple shuttle that I made from the lower half of a child's shopping cart toy. Any simple platform with wheels will work, the idea is to get the sewing machine up on an angle so that you can reach the area you need to sew. The sewing machine was placed on this shuttle and I was able to move the sewing machine along, sewing the 3 seams that I needed before I hand stitched the top and sides together.
Notice the mattress is also on an angle and supported by plastic clamps. This made moving the sewing machine along easier. Sandi sewed the fabric into the machine while I moved it along the seam. It was a a quick job once we get everything set up.
Three things to remember:
1. Sew down the length of the open seam top (sleeping side) of the mattress to bind the edge against unraveling. Mark your edge first, have extra material so that your sewing machine foot has plenty of room, then trim your top to the finished seam edge.
2 Sew down the length of the open seam top about 1" from the bound edge. This seam attaches the "Tyvec" like material to the top, this material is then attached to the steal edge rod with plastic wire ties.
3 Sew together the side panel of the mattress, the bottom and include the white bindery edge tape to finish the bottom. I was able to sew all but just a few inches of the bottom seam, I completed the bottom sewing by hand.
MHYZHEN
Posted: Saturday, May 31, 2008 6:52:41 PM
MHYZHEN
Posted: Saturday, May 31, 2008 7:00:44 PM
i just figure ...hey !....if your gonna make some sheets...might as well have ole Jeffy boy make some new mattresses !!!
sorry for throwin ya under the bus like that jeff !....
MHYZHEN
Posted: Saturday, May 31, 2008 7:06:14 PM
i found this on the web a year or so ago, i might have put some of the written stuff in the wrong places between the pics....but shouldnt be too hard to figure out........................has anyone tried this before, or made, or had made custom matresses for their BigM .............looks like it would be awfully commfy !
MHYZHEN
Posted: Saturday, May 31, 2008 7:08:35 PM
if you look closely at the last pic.........they custom cut and fitted a matress cover for them....i guess that was the original idea for the post......but the matress is just too cool to leave out !
EDDY
Posted: Wednesday, October 29, 2008 6:27:03 PM
dang I just had two new custom mattress made for the front birth , ORRIGINAL MATTRESS here made them for me,
about 5 1/2'' thick and pillow top... should sleep well, ...
The wife is looking for a recliner for the salon that isnt to wide ... She found one but it was $1200.00 ,
I /we dont really want to pay that kind of money for it....
Putting out alot of money now restoring her now that she is back in the water and rewired....
jsimanella
Posted: Wednesday, October 29, 2008 7:29:14 PM
What did the custom mattress cost?
Guest2
Main Forum RSS : RSS
This page was generated in 0.234 seconds.
