Ist project Options · View
Posted: Tuesday, November 18, 2008 10:08:01 AM
What size hose do you need?
I found some 1 7/8" for my exhaust but it wasn't easy.
The local marina ordered it for me and still has some extra left.
"LIFE is what happens to you, while your making other plans."
Posted: Tuesday, November 18, 2008 1:14:59 PM
..."The old shaft is pretty well pitted...."
That's because it was not isolated.
A good machine shop can cut a new keyway for the coupler end.
Posted: Tuesday, November 18, 2008 1:33:24 PM
A machine shop can cut a new keyway opposite the original and you'll be all set--as long as the shaft is straight. If not, get it straightened or buy a new one. A crooked shaft wrecks all kinds of parts.
trontek
Posted: Wednesday, November 19, 2008 7:24:09 AM
Rank: Member
I have a new shaft ready to install - my question is, should I hunt for brass keystock for the prop end? Computer Joe - I think I have the hose thing figured out(see above pics)
JIm
Posted: Wednesday, November 19, 2008 7:35:01 AM
Jim,
Defiantly!!!
BigBigMs Live On Applause
trontek
Posted: Saturday, November 22, 2008 8:00:11 AM
Rank: Member
The isolators I received will not fit my coupler. The OD of the shoulders on the spacer are larger than the ID of the holes in the coupler and the insulating washers OD will not let them fit the holes in the coupler. Will contact Marinette.com to see if John has a solution.
How long will it take the new shaft to rot without isolation(I'm 74yrs old....)?
trontek attached the following image(s):
Posted: Saturday, November 22, 2008 8:53:03 AM
Only 74? A spring chicken compared to one of our members.
No sense letting the hull to to pot for nothing. You can either drill out the holes in the coupler so the spacer fits, or grind off the protrusions (and use nylon tubes and faltwashers to isolate the parts). I have one each on mine. I'd recommend drilling the coupler out--much easier that way.
Jeff (only 65--a young punk)
trontek
Posted: Wednesday, November 26, 2008 1:49:22 PM
Rank: Member
Enlarged the four holes & dimpled the shaft. The shaft goes on and off by hand but does not wobble - should I french fit of try for new coupler? My engine is a Commander Ford w/a velvet drive gearbox. I wonder why the isolator John sent me didn't fit....the boat is a 1965 Fisherman.
RiverRatt
Posted: Wednesday, November 26, 2008 2:46:16 PM
Junk the old school isolator and get a Globe drive saver.
http://www.henrysmith.com/globedrivesavers.htm
The isolation is not to protect the shaft. It is to protect the hull from electrolysis.
Electrolysis can go quick depending on hull paint, hull protection, and water conditions (dissolved salts ect).
If you perceive that there are four possible ways in which a procedure can go wrong, and circumvent these, then a fifth way, unprepared for, will promptly develop.
Posted: Wednesday, November 26, 2008 5:48:24 PM
From the looks of that spacer, the normal isolator does the same thing.
trontek
Posted: Tuesday, December 09, 2008 2:42:34 PM
Rank: Member
Gotta get 1/4" longer bolts for the coupler since it was put together with no isolation before. GFO stuffing box packing in today(the pvc snapped over the shaft helped immensly[forgot who to thank], $105.00 trued and buffed 4 blade prop back on hopefully tomorrow(IF I can find some 1/4"x 1/4" brass keystock....).
Posted: Tuesday, December 09, 2008 3:55:01 PM
Jim,
Have U tried Napa for the 1/4" key stock. Are u sure it’s 1/4"? the key stock on mine are 5/16" & my props are 3 bladed. May I suggest one other thing before u install the props I just learnt this last season. First clean the shaft & prop tapers well then take a dab of graphite lapping compound not much put it the shaft taper than without the key spin the prop back & forth on the shaft this will help seat the tapers. To see the difference after the first step of just cleaning place the prop on the shaft as far back as it’ll go so U don’t need a puller to get it off & take a measurement them precede with the above lapping after cleaning off the compound with the same amount of pressure U use to test the set on the un-lapped shaft & prop take another measurement. Bet U say wow. I got near a 1/16" more set. If U don’t believe me ask your prop guy.
BigBigMs Live On =d&gt
Posted: Tuesday, December 09, 2008 4:25:33 PM
Lapping it in with valve grinding compound is a DAMN GOOD idea! Hydroplane racers do that with the flywheel to shaft fit. Keeps them from shearing keys.
Good one Norm!
trontek
Posted: Wednesday, December 10, 2008 12:36:34 PM
Rank: Member
Found the keystock and longer bolts today. After trying all the hardware stores and machine shops - found a boat shop with it(the same shop I called by phone at the very start of the search and was told they had steel but not brass). Will certainly follow the lapping advice.
Thanks,
Posted: Wednesday, December 10, 2008 1:10:55 PM
Jim,
Hope U bought a couple extra Whistle seems like they're scarce in that neck the woods Think
Posted: Wednesday, December 10, 2008 2:51:37 PM
If all else fails, one can get brass key stock @ WWGranger, but they only like to sell to business.
Posted: Thursday, December 11, 2008 4:53:07 AM
You can get brass key stock from www.mcmaster.com. Unlike Granger, they are happy to sell to anybody.
trontek
Posted: Wednesday, December 17, 2008 10:07:12 AM
Rank: Member
went to put in today but forgot to install rudder zincs - which prompts another question. I read to not mix zinc & magnesium. The current ones are approximately 3" x 6" rectangles and look good. The ones on the rudder were round and almost completely eaten away. Is there a way to tell what the material of the 3x6's is? I was gonna try to get by with just changing the shaft and rudder ones - but maybe not. The ones John send me are about 1" width strips and will require drilling. The new shaft anode(misnomer, I think it is a cathode....) is magnesium. John advised that the ones he shipped were for both salt AND fresh water. I'm in a quandry....
Posted: Wednesday, December 17, 2008 11:09:18 AM
If I’m not mistaking if U make a little pile of shavings & they’re magnesium add a flame to the pile they should flare up like gun powder wear safety glasses may be one of our scientist can confirm this theory Anxious
Posted: Wednesday, December 17, 2008 1:46:47 PM
Seeing you're in fresh water, I'd go for the magnesium. I have BOTH the usual Marinette load of SeaAlloy anodes AND a block of mag bolted atop one trim tab. Get 0.90 volts all year long, year after year.
PS: Your rudder anode is probably a garden variety zinc item.
Guest2
Main Forum RSS : RSS
This page was generated in 0.718 seconds.
