Let me be clear on this. Do you really mean .1 (barely reading) at the very very low end of the scale...or 1. which would be in the upper range of the scale? If the former, you have a problem. If the latter, you are right in the groove, no problem. That decimal point placement is key.
As already noted, different type zincs required in fresh vs salt water. But here is where my brain shorts...I am not sure but I think the aluminum/zinc bar is for salt water and the other kind (magnesium?) for fresh. I will gladly edit this post if someone straightens me out. If we could go back more than 6 months in searching the site, we'd have the answer for it has previously been posted.
If you have point-one reading (low end of scale), you have to start work. If you were getting ok readings at your previous location, and haven't changed anything on your boat then I'd look for external factors (like the zincs) and the other boats' hookups and the power feed to your boat. Usually, AC current is not your big enemy, DC is.
(BY THE WAY: While this is a good post it does not belong in the "Althouse" category. It should have been posted in REPAIRS/electrical&corrosion)
