First CAN project using Keil uVision (Updates in the text). Options · View
marinettejoe
Posted: Wednesday, January 02, 2008 1:19:22 PM
Code is zipped here.
Program uses the Luminary Micro LM3S8962 board with the evaluation keil compiler and the 2110 board.
The evaluation kit is available from Digikey for $79
Accepts 2 can messages from the board and displays either CAN 1 or CAN 2 depending on which button is pressed.
So far 5536 bytes of the 20K.
NMEACan1.zip (182kb) downloaded 113 time(s).
Unzinced ships sink at slips.
marinettejoe
Posted: Wednesday, January 02, 2008 1:31:30 PM
What's next.... I plan to set up the filter on the device to accept (read only) filtered messages (either J1939 or NMEA 2000). Something simple.
Barely readable is the CAN 2 message from pressing the #2 button on the 2110 board.
The 8962 data sheet is 1/2 way down the page.
http://www.luminarymicro.com/home/data_sheets.html
marinettejoe attached the following image(s):
marinettejoe
Posted: Wednesday, January 02, 2008 10:22:28 PM
http://www.luminarymicro.com/products/lm3s8962_can_ethernet_evaluation_kit.html I am using the EKK evaluation copy limited to 20K .
I have the Code Sourcery also, but am finding Keil a lot easier. The kit is $79 bucks from Digikey.
marinettejoe
Posted: Thursday, January 03, 2008 12:03:24 PM
Still gutting it from a sample project... Keeping something working... So far 20 hours invested.
marinettejoe
Posted: Thursday, January 03, 2008 12:10:40 PM
Have decided on the first project requirements. The project will read (only) all can messages and output them to serial/usb. Every 100 ticks or so Both engine Tachometers will be displayed.
Should be simple enough.
marinettejoe
Posted: Saturday, January 05, 2008 7:07:21 AM
I will not be posting those can /NMEA 2000 messages to the serial bus, but will write them to the microSD and a webservice.
Luminary Micro's 8962 kit is great. I have a sprintf memory leak... Time to use snprintf and get the C book out. Really wish I could use Bounds checker on ARM.
Those using new OBDII kits (Elmscan 5) will note that there is a can diagnostic kit. I may pick one up to hack it for NMEA2000.
marinettejoe
Posted: Sunday, January 06, 2008 12:47:13 PM
Here is NMEACAN2.zip.
Fixed the leak in snprintf. I needed to allocate heap of 200 bytes and 500 bytes to the stack) for stdio library calls. Idiot!!! standard lib calls need heap and stack memory. Sheesh. Brick wall
Currently the code is just CAN message handling from button press and is not much more than the LM code. I need to revise it for NMEA 2000 messages, so more protocol work and decoding. This seems to be the only NMEA2000 hobby project in process on the net.
It's design will be to collect CAN messages and allocate them to by PGN handler code as a dispatcher. Most messages will be ignored by the filter.
So far just about 30 hours invested. Faster than I expected.
The blurry pic reads
Hello World! Joe
Canx00000010 (Msg ID)
with Data Byte1 x01 (pressed can button 1).
This is 250K rate. The LM board is very nice.
NMEACAN2.zip (224kb) downloaded 60 time(s).
marinettejoe
Posted: Sunday, January 13, 2008 10:25:10 AM
Good paper on the address claim process URL http://www.agen.okstate.edu/Home/mstone/papers/Dynadr/dynadr.htm
marinettejoe
Posted: Saturday, April 26, 2008 6:32:02 AM
Status Still waiting on parts from wesgarde and an optoisolator from digikey.
I want to get the boat back, install the Maretron Fuel sender and the finish the kvaser test harness, to finish this out.
marinettejoe
Posted: Tuesday, May 13, 2008 7:53:58 PM
And still waiting. Was promised this on the 25th and is was supposedly sent out.
marinettejoe
Posted: Monday, June 16, 2008 4:56:59 PM
The parts are in.... Wesgarde came through.... Just need time to finish it.
Guest2
Main Forum RSS : RSS
This page was generated in 0.375 seconds.
