Spring Prep
#1 Posted : Tuesday, March 03, 2009 9:03:43 PM(UTC)
Spring is the time to make sure Your Boat will start fast, run smooth and perform at peak “E-
Fish-Ency.”
To help get you started, here is a checklist to prepare your boat for the upcoming Fishing &
“Martoony” boating season. Because there are so many different types of Fishing boats, be sure
to also refer to the owner’’s manuals for your boat, engine and (trailer if this applies) regarding
additional maintenance tips and proper service intervals.
Safety First!
Ropes: untangle, check condition, replace if necessary. Anchor Line soak in a buck of water with about 4/5 caps full of Woolite & a few ounces of bleach in a 5gal. bucket
Fire extinguisher: make sure it's the right class, fully charged and easily accessible.
Check date on Flares: up date if necessary (by Roger)
Life jackets and throw-able devices: double-check to make sure you have the right type,size and number of wearable and throw-able personal flotation devices on board (checK)your state’’s boating regulations).
First-aid kit: replace used items, store for easy access. Better yet buy a new kit if kit is several yrs. old
Documents: be sure your boat and trailer licenses and registrations are up to date.
Secondly make sure the FRIDGE is working properly to keep the BREWSKI’s COOOLD !!!
Exterior
Hull: clean and inspect; check aluminum for pitting, cracks, crevice corrosion . inspect
transducers and through-hull fittings. Make repairs as needed.the smaller the chip or bare
spot the hard it gets hit )-; If need be A/F the entire bottom Put a fresh coat of wax on the
Ole Girl
Propeller: inspect for loose shaft, worn key ways & keys, cracks and dings.
Zincs (sacrificial anodes): check and replace if worn out to prevent galvanic corrosion.
Hardware: check and tighten cleats, chocks, eyes, anchor, ladder, etc. Drain plugs: clean & put plumbers tape.on threads
Interior
Vinyl: Check for mildew, clean with marine cleaner or small amount of ammonia. Carpet: Clean with vacuum or power sprayer and wet/dry vacuum.
Bilge: Clean out scum and oil with marine bilge cleaner and wet/dry vacuum. Livewells:or fish coolers clean with nontoxic, biodegradable bilge cleaner, rinse thoroughly.
Chrome: remove any tarnish and polish all chrome trim. Electrical System and Components
Battery: check water level, clean and lubricate terminals, charge, connect and check under load. Do same for kicker trolling motor battery if this applies?
Wiring: Inspect all boat wiring, including lights, repair frays and breaks. Lights and gauges: check for proper operation, have spare bulbs onboard.
Fish finder, GPS, Radar & other electronics: reinstall if necessary, clean connections, check for proper operation, update mapping as needed.
Outboard Kickers
Oil and oil filter: change if not done during winterization.
Spark plugs and plug wires: check and replace as needed. A good way to see if U need
new spark plugs is water test them 1 take out of motor go on the dock gently set plug in the water if it floats it’s ok if it sinks replace it (-: replace all (-: I love this little ditty (-;
Gear lube: check for proper level, make sure it has no water in it.
Fuel filters: check and change as needed.
Hoses and clamps: check and replace as needed.
Fuel: check fuel tank, fuel lines and fuel level; replace primer bulb if cracked.
Fluids: check levels for engine oil, power steering, power trim.
Water intake strainer: check, remove any obstruction.
Bilge pump: check for proper operation.
Inboard Engines
Cooling system: check and change coolant as needed, store extra onboard.
Belts: check for tension and condition.
Transmission: check fluid level, see owner's manual for replacement schedule.
Backfire flame arrestor: check and clean.
Engine shaft and rudder stuffing boxes: check for looseness. & proper drippage
Trailer If this applies
Tires: inflate to proper pressure, replace if low tread or cracked sidewalls.
Rollers and pads: check, repair as needed.
Brakes: pull wheels, inspect/repair.
Bearings: repack bearings and hubs.
Tongue jack and winch: clean, inspect and lubricate.
Lights: inspect brakes, turn signals; repair as needed.
And finally, the single most important tip for your pre launch boat preparation: remember to INSTALL DRAIN PLUGS. You don’’t want to get that sinking feeling at launch time...it happens!
Once you’’ve got the boat ready, you can move on to the next item on your pre season checklist:
cleaning, repairing and organizing your rods, reels and tackle. But that’’s another story.
NOW that the vessel is ready for Launch it time too condition ones self for the boating season
first start out with a few BREWSKI”S a night till U build your system up to handle at least a
dozen or so with out making a A$$ outta oneself & waking up with a hang over. Next head on
down to the tanning salon & get rid of that fish belly white U inherited over the winter One wants
to look like he’s spent the winter down in Fl. chasing SorryDog’s Mermmaids around & not been
sitting in front of the PC chatting with a bunch of ole geezers & wishing to be year around
boaters(-;
BigBigMs Live On Applause
bruegf
#2 Posted : Tuesday, March 03, 2009 11:51:46 PM(UTC)
Norm, buddy, you must be getting old and forgetful - I can't believe that checking the fridge wasn't the first thing on the list :-)
Great checklist.
Fred
#3 Posted : Wednesday, March 04, 2009 7:50:53 AM(UTC)
Docsnow wrote:
Spring is the time to make sure Your Boat will start fast, run smooth and perform at peak “E-Fish-Ency.”
Thanks for the post Norm. Good stuff.
#4 Posted : Wednesday, March 04, 2009 7:59:12 AM(UTC)
Great check list, I really like your spark plug test! .Applause I would like to add Check expiration date on flares. I think mine are due.
#6 Posted : Wednesday, March 04, 2009 2:41:10 PM(UTC)
CONGRADULATIONS NORM!!Fantastic that someone knows boats and properly idetifies a boat carb filter as a BACK FIRE FLAME ARRSSTOR!
Safe boating
#7 Posted : Wednesday, March 04, 2009 3:12:36 PM(UTC)
Fred,
Safety First, Brewski second Besides it takes to cool them down to the right temp of 43* Whistle
#9 Posted : Wednesday, March 04, 2009 3:24:07 PM(UTC)
Dave,
Doesn't every one know that if not they should take a Power Squadron Boating Safety Course. That's been one of my peeves Brick wall forever about boating. If U buy any other vehicle U - R required some sort of classes etc. One throws a few hundred grand on the table the boat dealer hands U the keys & U out on the Lakes
creating havoc to other boaters plus ones self that goes for 90% of new boat owner Eh?
#5 Posted : Wednesday, March 04, 2009 8:55:46 PM(UTC)
OOPS !!! plum slipped my mind about the flares d'oh!  I’ll edit Spring To Do List A very important item to be on the list. To the members that have out dated flares & do want ignite them U can take them to the local fire dept. they’ll recycle them for U free of charge they use them at their training class, Just a suggestion Anxious
bruegf
#8 Posted : Wednesday, March 04, 2009 11:47:05 PM(UTC)
Docsnow wrote:
Fred,
Exactly, that's why you should start the fridge first. That gives you time to do the important safety stuff first WHILE the brewski's cool down. That's the new way - "just in time" processes :-)
Fred
#10 Posted : Thursday, March 05, 2009 4:28:55 AM(UTC)
Fred,
Ok , Fred in a couple of week when I head up to the boat I’ll take your enlightening suggestion on starting the fridge first so the Brewski’s get colder faster. Now wait a minute that’ll means my bilge monkey will just drink up the Brewski's faster & it’ll cost me more $$$$$ d'oh! Boo hoo!
Gypsy Girl
#11 Posted : Thursday, March 05, 2009 5:44:39 AM(UTC)
Beer is cheap ...Where do I get one of them there "Bilge Monkeys" Cabellas?
#13 Posted : Thursday, March 05, 2009 9:12:14 AM(UTC)
Well I know this town that invested 700 billion dollars in monkeys...
#14 Posted : Thursday, March 05, 2009 1:47:54 PM(UTC)
Spring is here already? Winter sure flew by. Must have been those mild temps from all that global warming that made this past winter so dangerously warm.Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar Liar
It's gotten so bad I'm daydreaming about painting the bottom. Need some boat therapy.
- Krazy Karl
#12 Posted : Thursday, March 05, 2009 4:03:47 PM(UTC)
Boo hoo!
You have to be nice to the # 1 mechanic at your sons place of business take him on fishing trips feed him give em lots of Brewski’s “only after the eng’s are running at peak performance” than U let him drink all the Brewski’s he wants. like the carrot on the stick trick Of course U also have to imbibe a few your self U Nose What Eye Means .Whistle
#16 Posted : Thursday, March 05, 2009 4:05:24 PM(UTC)
Karl,
I see cabin fever has set in on U also d'oh!
This page was generated in 0.237 seconds.
