Yoop:
From what I can tell, the original Marinette paint on my 1982 was a one-part air cured system.
It was a very good system for its time. Most of the paint on my big M has held up well considering
it has been stored outside in the weather for 27 summers.
I agree with your theory about the pinholes being caused by solvent from the primer or base coats.
The topcoat I'm using is by Akzo Nobel the makers of Interlux. It's a mil-spec aircraft coating.
I talked to the tech guys at A/N and they claim that it is formulated to resist impacts, abrasion, fluids, solvents and uv degradation.
One guy was very helpful and spent 45 minutes explaining industrial coatings to me. He said that in a few minutes, aluminum aircraft go from sea level to 50,000 where they are subjected to intense uv radiation. That's what causes paint to loose its gloss and then start to chalk.
Thermodynamics cause the aluminum to expand and contract which can cause cracking and delamination. This stuff is supposed to resist
those problems. The mil-spec of this topcoat also requires it to be compatible with several mil-spec primers from other sources. I should be able to use any of them. The problem is that most the primers are formulated to be very thin to save weight on the plane. I need one that will be high-build and impact resistant. I have the mil-spec numbers of all the primers that are compatible so my search is a lot easier.
