Simple shaft isloation test
halseyf
#1 Posted : Sunday, May 03, 2009 1:27:35 AM(UTC)
I am trying to find the old string on the best way to test shaft isolation. I put in new cutlasses and want to make sure everything still checks out. I am specifically looking for info on the most simple and acurate way to test isolation of the shafts and rudders. Any info?
Thanks!
#2 Posted : Sunday, May 03, 2009 4:18:13 AM(UTC)
Fields:
A simple electrical multi-meter set to measure resistence will work. One probe on the shaft and one probe on the hull.
Don't touch the metal probes with your hands or your body will register some level of conductivity.
If the boat is out of the water there should be almost infinite resistance depending on the accuracy of your meter.
In the water there can be a very slight reading caused by the water conducting electrons across the gap.
I will try to remember to take baseline readings this week before and after we launch.
halseyf
#3 Posted : Sunday, May 03, 2009 7:28:29 AM(UTC)
Thanks Peter
I went out to the boat to take a look at the way to test the shaft was and it was clear. However, the rudders are a bit different in my mind. What is the best way to check isolation of the rudders? I put one probe on the rudder (under the deck in the stern ,the very top of the stem where it sticks above the steering armatures) and one on the hull and my meter went to infinity. If the rudders do not appear to be isolated from the hull, what parts of the rudders or the rudder assembly could be contacting metal? Is their a process to identify what part of the rudder assembly might be making problematic contact?
Thanks much!
#4 Posted : Sunday, May 03, 2009 10:00:23 AM(UTC)
Don't forget that a "high" reading on an ohmmeter is "no conductivity". If you have a mechanical meter, then the needle should read at or near the left when on the highest "ohms" scale. If you have a digital meter, then you should see a big number, or the over-range. On many digital meters, this is " 1--- " or something like that.
This page was generated in 0.087 seconds.
