Quote:signed on today to ask if anyone has opinions on this latest gizmo from Marinco
This thing seems to have two functions: it detects reversed power and return (black and white) and detects direct current in the ground (green) wire. It looks very easy to use, just put it in line with the shore power cable.
Reversed power and return is a BIG safety concern, since all the gadgets on the boat are designed to keep you away from the hot (black) and aren't so concerned about the return (white) because white is at the same potential as the green, and the boat, approximately.
You can get a tester for a few bux at Home Depot or the like that plugs into a socket and shows various faults with little lights. This will test for reversed power, among other things. I leave one plugged in where I can see it. It has the advantage that it can be moved to check all the sockets, although you will see reversed power in ANY socket. When my marina was rewired, power was reversed on one of the docks, so don't trust even professional wire guys.
The electrolysis meter measures the voltage between the water and the boat hull, so if the reading is within spec (0.9 to 1.2) then the hull should be fine. If the reading is not within spec, then one of the causes could be direct current flowing in the ground (green) wire from the dock. This is tough to measure with a meter unless you have some provision for breaking the ground (green) wire while keeping the other two wires (black and white) connected. The gizmo does this very neatly. If there is direct current flowing, then the galvanic isolator in the green wire is defective.
I am not sure about $150. You can buy a nice multimeter for that. Not to mention the beer.
Quote:Now why is my grounding different as a diesel vs. a gas motor?
As far as I know, it is not. You should have a heavy wire running from the block (at the starter preferably) to the battery negative terminal, and another smaller wire running from the block to the hull. The factory provided a stud between and forward of the engines on my boat. You could also have a heavy wire running to the stud on the hull, and another heavy wire running to the battery negative terminal. This is electrically the same, and is convenient but adds another connection for the starting current to go through. Either way, you should have no resistance between engine block and hull. This differs from a gas engine only in the fact that you have a starting circuit but no ignition circuit.
Quote:How do I know my 3208s are grounded?
Use a multimeter and measure between a clean spot on the engine block and a clean spot on the hull. Verify the lead resistance by measuring with the two leads together. Subtract this lead resistance. You should be well under an ohm, my Perkins show no resistance at all on my cheap meter.
Quote:Could this have been overlooked when installed?
If your block is not connected to your battery negative terminal, you would have noticed by now. It is possible that both block and battery are not connected to the hull. If so, I would recommend a yellow wire, of at least the same size as the alternator output (red) wire, from a starter mounting stud to the ground stud on the hull. This should be the ONLY connection to the hull for all the motor circuits.
Quote:how (specifically) would I measure the dc and ac voltage between the ground slot and my boat's hull?
Plug the boat in to dock power, and turn it on. Put your multimeter on ac. Find the shore side of the galvanic isolator and put the probe on the terminal. touch the other probe to a clean spot on the hull, anywhere will do. Some voltage is normal, but more than 10 volts ac is a concern. Make the same measurement with the multimeter on dc. DC voltage will be slight, if any. More than a few volts is a concern.
Move to the boat side of the galvanic isolator and remeasure ac and dc voltage. The voltages should be gone. If they are the same as before, then the isolator is toast, and it is not grounded to the hull. Lift the ground to the hull and measure again. Voltages should still be gone, although some electronic meters are so sensitive that they will register (I prefer needle meters for this reason). If it looks fishy, take out the galvanic isolator and take it to a tech for testing.
Quote: And how do I measure the resistance from all three leads to my hull?
Turn off all your ac breakers except for the main breaker.
Disconnect the shore power cable from your power inlet. Conveniently, all three wires are there, on prongs. The prong with the bent edge is ground ( green), the middle-sized one is neutral or return (white) and the small one is hot (black).
Find a bare spot or screw for the hull connection. Put the other lead on another screw, and measure resistance. No resistance means you have a good hull connection. Move the other lead to the bent-edge prong. You should see a high resistance, because the galvanic isolator is between green and the hull and it is not supposed to pass dc. Check the neutral lead. It should show very high resistance because it doesn't connect to the hull anywhere. Check the hot lead. It should show very high resistance also.
Turn on all your ac breakers. This connects the hot to all of your loads. Note that the neutral is not switched: all neutral is connected together.
Recheck the isolation of all three prongs. They should still all be high. If they are not, then you have a short inside some ac appliance, and you can find the offender by disconnecting things one at a time.
Remember: The green wire, once it is past the isolator, is hull. The best way to mount ac appliances is to isolate them from the hull, attach the green wire to the frame of the appliance, and then hook up the hot and neutral. Neutral is at the same potential as the green, but must absolutely not be connected to green. If it is, then you have neutral all the way from the dock to your hull, unprotected by an isolator. When your appliance is isolated from hull and grounded with green, then any leakage from the hot lead goes directly back to the dock through the ground wiring and the isolator -- there is no current through the hull itself. Of course, if the leakage becomes a short, then a breaker opens.
I have a diagram of what your ac circuit might look like at
http://www.geocities.com...ette_Wiring_Generic.pdf
