All the Marinette gauges are standard automotive 240 - 33 ohm units, except of course the tachs. Many sell them, you might try fpmarine.com or surpluscenter.com. It is going to be hard to get a full set of matching gauges as surplus.
The tachs run off the ignition and can be driven by any squarewave. Using a resistor, diode, and small transformer will give you a calibration point at 3600 pps (60 Hz) from shore power, or 900 rpm for 8 cylinders. Sadly, my tachs run off the alternators which do not turn at engine speed so they cannot be bench tested.
Centroid Products has good prices on well-made fuel senders.
I would clean all the connections and resolder the terminals, and then test each gauge using the method elsewhere in this forum. Why replace working units?
