I'm posting this here because I didn't see a category that seemed to deal mostly with engine stuff.
Some may remember a while back I was having a problem with one of my engines stalling at speeds above an idle after running fine for about 30 minutes. The 30-minute "timer" was very consistant and it did not seem to matter if we were in choppy or dead calm conditions and the engine speed until the problem started also didn't seem to matter. I tracked it to the fuel tank by alternately switching both engines from one tank to the other. Many thanks to all who offered suggestions - all were beneficial and many were very helpful. I thought I'd relay the results because I was off the site for a while.
I ended up draining the fuel tank - used an electric fuel pump to pump it out through the fuel input connection. I took about 35 gallons of fuel out (fuel bought at $4/gal - sigh) and 2 of the 7 five gallon cans contained something that looked and smelled more or less like gas (to me) but would not burn even if you put it in a fire. It may be "evil-nol" but my research indicated that it may have the byproduct of mixing gas that contained MTBF with gas containing ethanol - mixing the 2 causes a "gunk" and it will not burn. Since few of us actually let our tanks run dry, it is likely that there was a good bit of MTBF fuel in the tank when the switch to ethanol occurred - and to call it a switch is probably kind - more likely it was MTBF/ethanol/MTBF/....... Anyway, whatever the case there was a layer of bad stuff in my tank.
BUT! After draining and cleaning fuel filters the best I knew how and adding fresh gas, I still had the problem - about as bad as before.
At that point, I really dug into the stock Perko fuel-water seperators that come standard on the '84 Marinettes - the ones that look a bit like upside down bells - they don't make them any more by the way. After messing with them a while I found another connection I could take apart and found this "filter" (I presume that is what it is) that appeared to be a piece of semi-pourous wood. It didn't appear to be clogged or dirty but I proceeded to wirebrush scrub it and forced air through it and reassembled everything and it has worked ever since like a charm.
My guess is that the "gunk" in my tanks probably floated on the real gas and it was only the little bits that mixed during jostling that made its way into the filter and engine and that an accumulation on the filters (mentioned above) eventually caused a problem. If I had let the tanks get low enough, there may have been a more serious issue with the gunk getting to the engine but the filters may have stopped that too.
I have not done so yet but I do plan to drain the other tank and won't let it get very low before then. I also plan to replace my filters with Racor filters with replaceable cartridges.
Richard
