If you want a "tender" that does not handle a load, you can get one that de-sulfates the battery by putting in a pulsed current at intervals, along with an amp or two for maintenance. They are about 40-50 bux.
This is all you need if you do not use the battery when you are not on the boat. I do not have them but some folks swear by them.
I use an old ferroresonant transformer that provides float voltage only, around 13.3 volts, along with a solar cell that provides each battery with an amp of trickle charge. If I lose dock power, at least my trickle charge works.
