, Member, Other Mods
Joined: 12/4/2007 Posts: 673 Points: 847 Location: Potomac MD
Out for a short ride Saturday with a marina mate, he notices volt meters and remarks that with both showing only 12 volts there is a problem. I tell him that it's the normal reading and I don't think there is a problem. Five minutes later, wham, he jinxed it -- the starboard meter drops to under 10 v and that ain't normal. We head back to port before the battery dies.
Also needed to mention problem B: when I got onto the boat just before taking the ride, the stbd battery bank (2 batteries in parallel) was dead and I turned on the battery charger for a just few minutes before heading out. Using the solenoid xover switch, the stbd engine cranked over smartly.
Overnight Saturday, the stbd bank charged fully. Today, I put a meter on the batteries and it showed 12.6 v at rest (after that full charge) but the only same voltage with the engine running, not the expected 13.5 or so volts.
That says to me that there is an alternator problem. It's a rebuilt unit put into service only about a year ago. Tips on how to proceed are welcome. I may have rebuilt the old, original unit as a precaution so there may be a backup on the shelves.
The belt: Is it tight enough? I ask because I can turn the alternator by hand,
, Member
Joined: 12/5/2007 Posts: 2,016 Points: 3,863 Location: New Tripoli, PA
1. Fully charged batteries should be 13.5 to 13.65 volts.
2. You need to check them with the charger OFF
3. Alternators are not designed to 'bring back' a near dead battery. It takes HOURS of running to do that, and
4. Check the water levels in your batteries. I bet you'll be stunned at what you find!
Only 40 days 'til splash time!
Rank: Advanced Member Groups: Member
Joined: 5/26/2009 Posts: 30 Points: 90 Location: Michigan City In.
If you can just the alt by hand the belt is very loose and possibly glazed up. With the engine running at a fast idle you should see 13.8 to 14.2 volts at the battery. Alternator belts need to be very tight and you should be able to turn the engine over by hand with the alt. Rick
Joined: 12/4/2007 Posts: 207 Points: -143 Location: Lake Barkley
Our remote regulators are often part of the problem. I dealt with it by changing to new one wire alternators. You have to run new heavier wire from At. to you battery banks but they work much better. Slightly larger output 62 amps but still single belt. Masco was an excellent source.
1. Fully charged batteries should be 13.5 to 13.65 volts. ooh. Mine are just under 13 after a 14 hour charger session. 2. You need to check them with the charger OFF that I did. 3. Alternators are not designed to 'bring back' a near dead battery. It takes HOURS of running to do that Right, didn't expect it to charge in minutes. 4. Check the water levels in your batteries. I bet you'll be stunned at what you find! thnx. I topped just a few wks ago but will recheck. Jeff
If you can just the alt by hand the belt is very loose and possibly glazed up. Rick ok, thnx...I now know have a pair of loose (but new) belts. As a parting shot yesterday, gave both belts a few squirts of "belt dressing".. but don't think they are glazed
Dave..will look into new alternator .. again..thnx.
Joel, Belt dressing is a big no no. All that does is make a big and hard to clean up mess and if you get to much on it will cause the belt to slip even more along with some noise. The best thing to do is to clean the mess up and properly adjust the belts. New belts will stretch after a running for a while and will need to be readjusted. Check you batteries with a hydrometer and look for one or two cells with a low reading. An even better test would be a load test as this will test the internal battery connections along with the cells. A properly set up alternator will do a much better and much faster job of charging a dead battery that a 10 amp battery charger. The exception to this would be a late model automotive alternator which is not happy doing a major recharge. The ones on our boats do a good job of recharging a dead battery. One safety note -- a dead battery that is in poor condition will gas off when charged and this gas is very explosive so watch the sparks. DO NOT CONNECT OR DISCONNECT ANY THING FROM A BATTERY THE IS GASSING.
Joined: 12/7/2007 Posts: 749 Points: 923 Location: Central Florida and the DC area
Marinette wired the voltmeters to the same ground wire used by everything else in the panel. This causes a voltage drop in the ground that makes the voltmeter read low. Additionally, the hot side is connected to purple ignition voltage, which is lower than the actual battery voltage. Ideally, you would wire the voltmeter directly across the battery. This isn't very practical.
You could try wiring the voltmeter negative directly back to the engine block, and connecting the positive to the ignition terminal on your ignition switch, to get a better reading. I just got fed up and I wire the voltmeters directly to the batteries. This won't work for everyone because automotive meters draw current. For direct connection, you should use high impedance meters. Common panel meters are 5000 ohms/volt and so will draw insignificant current.
Before getting carried away, put a digital VOM across the meters to prove that they are working correctly.
From Rick:"...A properly set up alternator will do a much better and much faster job of charging a dead battery that a 10 amp battery charger...."
-describe, pls, "properly set up alternator". thnx
From Doug: "I put the VOM across the battery but wil also check the voltmeters." -Mine traditionally read low, only around 12 v, so your description may explain why. I always regarded that as normal, typical readout. So, when both upper and cabin meter on stbd side dropped to 10 v, I suspected a problem. New unit (rebuiilt, that is) now sitting on the boat waiting for yard's attention.
Jeff: I think I traced the wires as you described them in our conversation. But still not sure whether regulator is external
, Member
Here's what they looked like (I removed them with the one wire setup). Jeff
Fastjeff attached the following image(s):
Joined: 11/4/2008 Posts: 55 Points: -23 Location: Lake Erie, NY
Water to be added to the battery should only be distilled water. Adding municipal or well water to your battery will contaminate the acid solution with dissolved limestone, [hardness] and caustic soda used to reduce acidity from flouride additives. These alkalines react with the acid to produce salts and your battery's strength and lifespan are shortened. Cheap battery chargers left on continuously will "cook" out the water in your battery. Ideally using a three stage charger to maintain your batterys is what is needed. They start out strong at some rated at ten amps, then drop to a finish charge of two amps. When the battery is fully charged, they then perodically send a .02 amp charge through to keep the battery topped off. There is a system where the charger will choose which battery bank needs a charge and then alternates back to the weakest bank.
A properly set alternator or should I say charging system should have ----a tight belt that does not slip --be able to put out its rated amp and volt output -- have good wiring connections to the battery -- not poor grounds -- a battery that can take a charge Rick
Jeff: Great photo w/captions. I will have to get unlazy and remove the metal plate that covers the electrical components, the one with the big (2")rubber plug in it and check what's underneath. It's a PITA job. Jim: I agree with your post and use distilled water. Also, I don't leave charger on even though it's supposed to do all you describe (Charles brand charger, about 12 yrs old) except, perhaps, select between the two battery banks. Rick: Order #1 for the yard is to tighten belts on both sides since there is obvious slippage. Wires all appear tight & clean. Glad you posted that for everyone's benefit.
, Member
I tossed that cover out years ago. Too hard to get back on, and it can hide things I want to know about.
I have seen a number of alternator problems that were caused by poor connection between the alternator and the block. Automotive wiring harnesses often lack a ground wire just for the alternator.
A good cure is to run a heavy (8 awg) wire from the ground stud on the alternator case to the same bolt to which the battery ground strap is attached. The recommended attachment for the battery negative is to one of the bolts that secure the starter motor to the block. That way the battery gets hooked directly to the case of the starter.
Doug..any idea which one is the ground stud? there are two wires attached. One, heavier gauge, appears to be pos output. But there are no markings on the unit (I think) suggesting the other is ground/neg. Also, a wire runs from the alternator to the fuel pump. Does that mean that the factory installed an electric pump?  File Attachment(s):
, Member
You have a mechanical fuel pump--see doctored photo. Jeff
Ok..my eye was fooled into thinking that is an electrical connecton when it is indeed, the fuel line sneaking behind the alternator.Crafty thing
The output for the alternator is usually easy to spot - it is an insulated stud, often with a plastic guard, and the wire attached to it should be heavy and either red or orange. Red is common on automobile engines.
There is usually another connection, small wire, that goes to the (purple) ignition. This powers the regulator. If you have an external regulator (rare these days) then it is a field connection and will go to the regulator.
The negative is internally connected to the alternator case, so the whole shebang is negative. Usually there is a stud mounted to the case directly to permit attaching a wire. When you put an eye terminal on the stud (using an aircraft nut, please), the connection is normally made directly to the case. On some (older) cars, the designers assumed that the connection to the block would be through the brackets. This is a bad idea around water. New harnesses have a black wire that is supposed to go to the case. Better to go directly from the alternator case to the block yourself.
Joined: 2/7/2008 Posts: 127 Points: -286 Location: Knoxville, TN
My voltavge meters have always read a "hair" over 12 volts and I too felt it was normal. About every two or three years the starboard meter would fall to 9 or so and I knew I would have to replace the external regulator; I keep a supply of spares. Now, after reading of the virtues of the "one wire" have purchased one. but no wiring diagram was included to help me know how to bypass the old external regulator. I've read several posts about the issue but haven't been able to determine the exact procedure. Great pic Jeff and Joel. Jim
Guest2 |
