water in bilge under galley
scubaJ
#1 Posted : Monday, June 29, 2009 3:41:43 PM(UTC)
I have accumulated foul smelling water in the bilge under the gally of my 37 ft Sedan Bridge. I have tested the shower sump and float and do not see drain hose from shower leaking. Also do not see the discharge hose leaking.
I replaced the sump pan, pump and float last year, and it holds about 1 inch of water at all times. My Cruiseair AC units have a condensate return that pumps overboard with the water source cooling discharge [or at least that is where I think it goes, since there are no condensate drain pans, etc. ]. The forward bilge pump chamber is pretty dry.I have also checked the area under my Purasan wastewater system and see no leaks when the unit is turned on [flushed]. I am stumped as to where this foul smelling water comes from. Anyone else out there had this problem?
#2 Posted : Monday, June 29, 2009 4:06:03 PM(UTC)
Trace that AC condensate drain line. Watch the condensate come out. Mine leads to the shower sump that I once forgot to turn on and got a whole weekend's worth of condensate water under the galley floor. The sump power switch now stays open all the time.
mark
#3 Posted : Monday, June 29, 2009 4:07:50 PM(UTC)
mark
i had the same problem on my 41 it was the a/c pans they were just drained to the bilge i plumbed them to the fwd shower sump problem solved
mark
Rick100
#4 Posted : Tuesday, June 30, 2009 3:02:02 AM(UTC)
Rick100
How about the sink drains or the hot and cold lines to the sink.
Miss Cleo
#5 Posted : Tuesday, June 30, 2009 4:51:43 AM(UTC)
Miss Cleo
My vote is that it is the A/C condensate - should be a tray under the units (you probably have 2) with a hose going to the shower sump - was disconnected from the sump when I bought my 39'. Short of that, on Miss Cleo that area has an abundance of thru-hulls, hoses, filters, and pumbing of all sorts - could be any of them. A thought - turn on your A/C units and verify that no water is leaking from the input cooling water filters - I had to replace the cover gaskets on mine.
Also, on Miss Cleo any water that drains from the anchor rode ends up there (minus the amount that can be pumped by the forward bilge pump) so if you anchor a lot ..... I have plans to install small bilge pumps fore & aft to get more of the residual left by both the forward and aft bilge pumps.
Richard
#6 Posted : Tuesday, June 30, 2009 5:48:05 AM(UTC)
Do you have water in the bilge or just the foul smell? If you anchor a lot open your locker door and let it vent and dry the rode down.
#7 Posted : Tuesday, June 30, 2009 10:55:30 PM(UTC)
I'm starting to appreciate my roof mounted AC unit. Lot less complication and having far less potential problems. Less efficient, but what the heck; I pay for the electricity on a lump sum basis anyhow.
#8 Posted : Wednesday, July 01, 2009 12:26:55 AM(UTC)
Jeff.. I agree with you. The marine circulating units are nice but more complex and actually if you are in warm water your unit is more efficeint. Here when we need it the most the water temps are close to 90 degrees! Not much cooling effect with the marine units when water is that warm.
I have been looking at a roof unit..they have some very slim units now and thought it might fit on up on the bridge under the bench helm seat? No Genset so have not done it I am not much for sitting at the dock when my boat is only a couple of miles from AC in house..
Always something I want to put on the boat though.
#9 Posted : Wednesday, July 01, 2009 5:32:55 AM(UTC)
Dave:
My boat came with a seat neatly placed atop the AC unit. The one I replaced that one with--a Coleman RV unit--is even lower.
scubaJ
#10 Posted : Tuesday, July 07, 2009 3:09:31 PM(UTC)
Sink supply and drains outlet thru hull above waterline and show no leaks
Shower pan drains thru hose into shower sump pan and pumps out
CruiseAire AC units discharge sea water above water line and I cannot seem to find either a sump pan or a hose from the A/C uit area to tha bilge to connect to shower sump and the bilge in the area of the ac's is pretty dry. Haven't had the boat off the dock long enough to anchor-seems to rain and screw up river every week. I will keep looking for condensate pans and drain. One of my dock buddies also thinks that's my issue. thanks for the input
The HedgeHog
#11 Posted : Thursday, July 23, 2009 1:06:56 PM(UTC)
I just went down this path too.
It is more than likely the A/C Condensation. I had to crawl around a while to figure this one. I woke up early the other am while staying on the boat and took out the whole wall in front of the AC to get in. Voila, there it was! The water flow was pretty subtle so it was not all that obvious at first. My AC condenser would dump out right at the water line so it's pretty tough just to tap into a through hull. I am plumbing lines into a shower sump.
A dry front bilge is a happy front bilge!
scubaJ
#12 Posted : Wednesday, September 09, 2009 9:06:02 AM(UTC)
I have studied situation all summer and am positive that the source of the water is the drain pan from AC condensate. There is a thru hall below the ACU in the V berth but the drain hose no longer connects to it. The hose goes down thru the dresser cabinet alongside the drawers and barely thru the floor plywood and dumps into the bilge. I have to take the carpet up, remove the floor and extend the drain to the thru hull or the shower sump this winter or next spring. I cannot get to it from the shower pan access hatch
rrbrown
#13 Posted : Wednesday, September 09, 2009 11:13:42 AM(UTC)
rrbrown
We had a smelly forward bilge as well. I found that the black coating (tar) at the keel had lost it's bond with the aluminum and was trapping stagnant water. I removed all of the loose tar and gave the bilge a good cleaning. It was a huge improvement.
I also installed a Whale Gulper 220 shower pump directly to the shower drain. That eliminates the soap and scum in the shower sump. The shower sump is now only used to collect the condensate from the A/C units.
Rob
MISTY BLUE
1986 39' Marinette Aft Cabin
6.5 kW Westerbeke Generator
Home Port: New Buffalo MI.
This page was generated in 0.262 seconds.
