Repainted the boat 10 years ago with Awlgrip. First places the new paint lifted were areas that were heavily faired: the corners where the forward built in bow seat (flybridge sedan) meets the deck. It happened so soon after painting, I was able to get the area Awlgrip rep to come to the boat to see if there was a problem with the paint itself. His opinion: the solvent in the fairing was still escaping 11 years after it was applied at the factory and lifted the paint. Don't know whether to agree with his finding but Karl mentions it now so it's something to keep in mind. There must be a way to seal in the solvent with a prep coat.
One rule that is a must-follow: the etchant coat has to be applied
within a few hours after sanding to bare metal or sand-blasting. And from what I observe on the boat today, I believe that a total sanding or sand blasting is unnecessary where the existing paint bond is firm.
My guess is that you are dealing with a boat where the factory paint is chalking. Many Marinettes had that problem. But a good sanding following by an epoxy paint will be good prep in areas where the paint now holds.
By the way, you can save money in the paint project if you remove the deck hardware yourself. And see Jeff's post on reattaching the rails for a great tip on how to stave off corrosion on the deck.
Good luck with your project, keep us updated
