Looking for a source of power for my edlebrock electric chokes. Looked for power at alternator output....constant pwr from battery at terminal...Looked for power at field wire on alternator and voltage regulator...power is too low because it runs about 6 to 9 volts.. I need a full 12 volts plus with ignition switch only. I do not have a resistor for ignition....at least I have never seen one
1) Any of you guys with 1985 or later have resistors?
2) What is the power source for your electric chokes...if you have them?
3) Guess I could tap into Electronic ignition control module wire???? Not sure if there is a full 12 volts there somewhere.
I've seen a thread on this before, just can't find what I'm looking for.
