Marinette Parts
marinettejoe
#1 Posted : Thursday, January 10, 2008 5:58:28 AM(UTC)
marinettejoe
Sources for Marinette Parts.
As Always John Althouse at Marinette Yachts... www.marinette.com. Great guy and a great company. Wish he was closer to my boat.
Spring Rear Door Locks: Stanley barrel bolt spring locks # 75-6400 and CD2003
Sea Strainers:
San Juan Engineering & Manufacturing Co. 766 Marine Dr. Bellingham, WA. 98225
Ph: (360) 734-1910
Fax: (360) 734-9683
Strainers: Buck-Algonquin carries San Juan or functionally equivalent units and stocks gaskets
AC Breakers in Panel:
Airpax breaker switches (identical to Carling breakers): http://www.pocosales.com/
http://www.colehersee.com/home2.asp
Airpax:
2610 SE Willoughby Blvd.
Willoughby Business Park
Stuart, FL 34994
Phone: 772-463-4588
Fax: 772-463-4568
E-Mail: sales@airpax.com
Web: http://www.airpax.com
Lenses for port/ starboard bow lights:Perko # 281 DPALNS they come in a package of P & S lens's
Exhaust Manifold Gaskets that fit: Fel Pro # 93749 or gaskets for a 273 cube Chrysler V-8
Better Ignition Wires:
Aqua Power (Morse) # 3038 for a big block Chevy—try to get angled plug ends (which has a different number)
Oil Pressure Switch (for Eng. Alarm):NAPA # OP6079
Note: The oil pressure switch has a single, screw on connector; the oil pressure-sender unit has two spade connections.
Temperature Switches (for alarm):Hypertech (Jegs) 160 and 200 ‘ F “fan switches” (come with 3/8 NPT threads)
Stewart Warner temperature switches, 83300 series for 1/2 NPTF with screw terminal and 200 F, part # 83308
Plastic Stuffing Boxes for Rudders:
http://www.marineparts.com/sierra/sierra401.aspx
Gasket for Bomar Hatches:
http://www.pompanette.co...fe8439852567c5000f8a35?
Aluminum Rivets and Etc.
1. Rivet nuts: McMaster-Carr # 94020A323
2. Stainless FH #8-32 x ¾ “ bolts: McMaster-Carr # 91500A197
Shafts:
Per John Althouse, the SS shafts on a 32' Sedan Bridge are 60".
Marine Machining. Call 586-791-8800 (Detroit) $320 per shaft
St Louis: Marine Technology. Call 636 899 1000 ask for Jerry.
Split Couplings:
Henry H. Smith & Co. #109-50- 500A. Specify shaft size. ($120)
1-800 -338-8900 (Michigan)
Note: Bore is deliberately undersize and will need slight reaming/ sanding
Shaft Zincs: Boatzincs.com
Electronic Control Unit (4 or 5 prong is okay): NAPA: Under 30 bucks
K & N Filters: K & N part #59-3314. These are 14 x 4 3/4. The intake flange is 5 1/8. Use 2 feet of 1/4 inch threaded rod to attach. You have to specify the hose diameter for the adaptor as well (measurement #3.)
Control Cables: http://www.go2marine.com...earch&x=11&y=11
Throttle cables for a 32 footer:
13 foot Morse 33C red cable: # 032377-003-156 (Starboard, lower helm, 32 ‘)
16 foot Morse 33C red cable: # 032377-003-192 (Port motor, lower helm, 32 ‘)
Morse Shifters:Charman Enterprises sell service parts for Morse Controls (800) 247-6324.
Morse Controls (610) 495-7011
New Chrysler Engines: Marine Power Services Inc.—New Jersey
Mag Anodes Source:
http://www.engineeringsh...ForCat/mktID/1/catID/1/
http://www.globalcathodic.com/table6a.htm
Source for Marinette Aluminum:
http://www.advancedmetal...dvanced-Metal-Logistics
http://www.adimetal.com/
Note: Boats are made of manganese, magnesium alloy called 5086 – H116.
John Althouse said the correct welding wire is 5356
Silver-Silver Reference Probes:
http://www.farwst.com/fwst/refelect/gmc09.htm
http://www.boatzincs.com...eference-electrode.html
Rebuilt Alternators:
Park Manor Sales and Service
915 Greenleaf St. (near 9th)
Allentown, PA 18102-1473
610-770-9488
Nautalex Source:
Mayea Marine Store
8779 Dixie Hwy.
PO Box 230430
Fair Haven, MI 48023
(586) 725-6111
‘Rollers for Screen and Glass Doors:
Blaine Window Hardware, Inc. Hagerstown, MD 800-678-1919; 301-797-6500;
Trans Heat Exchangers:
Oil cooler dimensions: Length 12 inches overall/ 7 inches between fittings, 2 inch diameter.
From Marine Parts Source: oil cooler RD 209 EE 05 -- $89.85. Call (866) 388-0390. http://marineengineparts...c/store/html/page4.html
Oddball/ Light Bulbs Source: http://www.topbulb.com/default.asp
Chrysler Sparkplugs: Champion RN9Y gapped to .035 “
Windshield Wipers; ANSCO 91-16
Belts:
Alternator: NAPA 25-7440
Water pump: NAPA 25-7470
Chrysler Engine Parts:
http://i-netmarine.com/index.html
http://www.ebasicpower.com
T-Stats (140 degree):
Large diameter T-stats: http://www.marineparts.com Call them at 561-748-0053 for the large 140 ‘ F t-stats
Small diameter T-stats: NAPA (Sierra parts book). Part #18-3551 for 140 ‘F
Water Pump impellors: Sherwood 10615K impeller (for the single impeller punmps). www.boatfix.com (Part # SHE 10615K). They come with the gasket and O-ring.
Water pumps: Marinepartssource.com (carries Sherwood units, favorable pricing)
Trilux Bottom Paint (very good pricing, often free shipping) WHolesalemarine.com
Used Boat Parts:
M&M Marine Salvage in Meredith, NH. (603) 279-5041 (George)
Rudder Bearings:
For 1" rudder shafts - Bearing Size = 1" ID x 1-1/2" OD x 2" Long (2 are required per rudder shaft, one at the top of the rudder log and one at the bottom.) These are made by cutting a 4" bearing in half.
Marinette Window Curtain Track Hooks:
www.sailmakerssupply.com Tape for making interior Marinette window curtains.
Aluminum Drapery System - #60434 is the nylon tape that is sewn into the curtain with the nylon tabs that run on the aluminum track. Aluminum Drapery System - #60435 is the little rail stops.
Jean Sheldon Sailmaker's Supply 1-877-374-7245 http://www.sailmakerssupply.com
Variety of Chrysler engines, parts & Marinette-specific supplies (former Marinette sales agency) Marysville Marine, Ohio
Circuit breakers (aircraft type on-off switches): We made a long informative thread titled "Airpax Breaker Switches" Here is the catalog link: http://www.airpax.net/si...pax_PPP_SNAPAK_0106.pdf
#4 Posted : Sunday, November 29, 2009 5:56:53 AM(UTC)
Oil Filters
I have '85 twin 318s. I am sure these part numbers work on all mid 80s 318s.
Oil filter part numbers
NAPA Gold FIL 1068
Wix 51068
K&N HP-2004
Sierra 18-7819
Fram PH43 or PH16
marinettejoe
#6 Posted : Monday, May 03, 2010 6:11:46 AM(UTC)
marinettejoe
I believe Teleflex Sierra still makes the 49409 Delrin Plastic rudder stuffing box. Trying to confirm if this works for Marinette rudders. Any experience?
http://www.teleflexsierra.com/
Search for part 49409.
This page was generated in 0.371 seconds.
