On the trip up to the cardboard boat race the port motor started to drop down then back up to the point that I had to back her down. This started after running at 3000 rpm for a while. At 2 to 25 she ran fine. both motors draw off the same tank. New fuel pump last year and the filter and seperator are fine, new ones and same thing. HELP
Mike
Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
i had the same problem .make sure your gas valves are all the way open and and there are no restrictions or air leaks. tim 72 32' express "http://www.theboaters.com/boats/Powerboat_Express_Cruiser_marinette_1972_anticipation"
Groups: Admin, Administration Joined: 12/4/2007(UTC) Posts: 1,117 Points: 665
NightMoves wrote:the port motor started to drop down then back up to the point that I had to back her down. This started after running at 3000 rpm for a while. At 2 to 25 she ran fine.Mike Have you checked the small (thumb -size) filter where the fuel line plugs into the carburetor? Joel Albert, Potomac MD "Charlie B" - 1988 32' FBS Twin 318's/FWC/16x15 nibral props docked Deale, MD
New eldebrock carbs so no filter in the carb that I know of. Did replace the inline filter and the water seporator
Mike
I had almost the same problem with my 318's it wound up being the pick up in the distributor It would sound like it was running out of fuel, only did this after warm up. The new pickup cured the problem I had a spare so it was no problem to see if that was the issue. I now have the same problem with the other motor I will change the pick up and reluctor to see if this will cure the problem. Bob V.
