You may remember my saga from last fall. I didn't work on the starboard engine much this year because I pulled out the interior. Installed new panels (luan covered with those recycled plastic panels), had new countertops made (white laminate) and new bulkheads covered with the same white laminate. Now that I'm nearly finished with the interior--got most of the galley back together today--I'm focusing again on the starboard engine.
After installing a rebuilt water pump that did not draw water through the strainer and letting the mechanic of the day at the marina try to fix it--and you guessed it, he put it in backwards once so he had put two impellers in on top of a new thermostat--I ended up installing a new water pump. Still no water pulling through the strainer. Today I installed an o-ring on the strainer and a new domed top. Last week, I pulled both hoses off both the port and starboard sea-cocks and the flow out of both was the same. Just to check, I pulled the hose off the transmission cooler and water came out. It seem some water is getting drawn, but you can't see it going through the strainer like you can with the port engine. Today, I got the strainer top on so tight, I had to yank it to get it off--kind of a suction effect. Still not drawing water through the strainer. Last year I pulled the transmission cooler and ran a coat hanger wire through all the holes.
What's left?
Thank you.
Joe
1977 28' Express
Twin 318s, raw water cooled
Ohio River
