collins69s wrote:Why don't you just run the engines till warm up/thermo opens ? Run it the whole time on the pink.. Isn't that the easiest, most efficient and thorough way?
Sean
How many gallons of AF would you go through before the thermo opens? 30 gallons ???
Here's how I do it (my boat stay in water all winter):
1) Remove two block drain plugs (per engine), let drain, turn over engine starter a few times to get water out of main water pump,then reinstall plugs.
2) Remove 4 plugs from exhaust logs and elbow (per engine), let drain, then reinstall
3) Remove thermostat and pour in pink AF until block is full.
4) Install t-stat and cover.
5) Open salad bowl (water strainer)
6) Admiral starts engine while I pour 3 gal of pink AF through strainer (never run a sea pump dry). Turn engine off.
7) Pull coil wire and ground coil with jumper wire.
8) Spray Sea Foam down carb while Admiral turns engine over 15 seconds.
Crack open a cold one and wipe my brow.
I think I cover all bases...
I learned all this here on the forum..Can you guys see any holes?
Quote:Jack:
I don't pull the t-stat hoses, I remove the thermostat itself to allow the pink stuff to immediately circulate through the block.
As you can see in the diagram below, the raw water pump will split the flow between the circulating pump and the top of the t-stat housing. With the t-stat in place and closed, the pink stuff will bypass the block and go straight to the manifolds.
Phflaw,
My understanding of the raw cooling system is water comes in cycles through sea pump which supplies the main engine water pump. Then the water goes through the lower part of block and flows to the upper part of the block and out of thermostat (if open) then out fo the exhaust.
I found a great diagram...
Here I know this is a car engine, but ours should work the same except for exhaust cooling which is supplied directly from the sea pump.
