Your right on about where its at, in the access compartment behind the helm; as you probably already know on these 28ft's not much room and is in the head. As far as the bilge goes , i put 2 new pumps and float switchs and new wireing in a protective sleeve, didn't see any traces of this wiring. I dont use my bilge switch on my helm panel, think its kapoot. Everything on my panel works except the panel lighting. Removing this will be a nightmare, will most likely need a good marine sparky. Should have done that back in March when i had the cabin gutted. Like i said before , she had a good 1-1/2 FT. of water in the cabin
This past month i've redone the head but am thinking of taking back out counter,cabint and head and removing the wall behind the helm & make a bigger access . Would like to put in a new terminal block or upgrade, this one looks like it has seen its days.
Going up today to check my cabin and engine compartment heat. going to be pretty cold this week. Think i'll try to trace the wires again. Might take a pic if i find out wear it goes. Not to many people here to talk to ,even at the marina, they bring them in from Ktown. Sorry i went on so long !
Mark
Knot Normal
28FT. Express
Twin 318's
Ten Mile Tn.
