2 Pages12>
318 water jacket for Plucke River Cruiser 1969
rmakkay
#1 Posted : Wednesday, January 20, 2010 2:58:15 AM(UTC)
rmakkay
Hi folks. Happy NY to you all.
Well, the freezing weather finally got us. Went to the boat last weekend to find that cold air blowing around was enought to freeze the cast iron water jacket (I think that is what it is called...) and create a 2-3" crack . Not a huge mess and still seems to be a solid part.
Questions/thoughts: I have talked to some older welding folks and farmers and they suggest that the part could be welded with nickel rod or brazed. Maybe best to heat it up to 1000F first, etc. Have heard about hammering it immediately after welding to relieve stress.
Have heard also about using JB Weld after thorough cleaning/grinding and drilling a hole at each end of the crack to stop any further cracking. I think that might be my best bet since the pressure is low and temps are never higher than 180F (more like 160F in my boat). Will use a dremel with a small grinding wheel to do a dentist's job on the crack to be sure the JB gets a good hold too.
Thoughts? And my question for everyone is this: is there a place I can get another one of these parts? It is cast iron of course and has the water pump bracket too, on the starboard side. All cast together. Has a camshaft timing indicator cover (big threaded cover). I guess it is stock stuff. The boat has a Paragon v drive so the trans is up front.
Any help or suggestions would be wonderful. THanks in advance for any links or wisdom you can offer. Best to you all and I hope everyone has a great season!!!
Rich
#2 Posted : Wednesday, January 20, 2010 3:38:37 AM(UTC)
I hope this is a fresh water cooled motor! If it's raw water cooled, you'll find a few more cracks when you fire it up.
Jazman
#3 Posted : Wednesday, January 20, 2010 4:25:49 AM(UTC)
Jazman
Not sure what is actually cracked...can you take some pictures for us?
1975 37' FB Sedan
Sleepless Knights
Bohemia River
Chesapeake City, MD
rmakkay
#4 Posted : Wednesday, January 20, 2010 11:08:29 AM(UTC)
rmakkay
UPDATED.... posted pic
Thanks for the replies.
The engine is cooled by lake water. I guess that is "raw" water?
I am hopeful that the engine only has this one crack. A beer bottle with water in it that I placed back in year 2 (capped with no airspace) didn't break, so I was suprised to see this crack.
I heard that while I was gone the marina got down to 7 degrees for three days in a row. I bet on one of those days there was enough cold air moving around inside the motor compartment that it and only it got chilled. Kinda sticks out. See the pic I just attached.
First year, I winterized. Second year, winterized but put the beer bottle in place. It was a cold one, and the bottle never broke. Years 3-9, never winterized. This year, well, you see......
I'm betting that this is the only thing that froze. The hull is aluminum so it stays pretty warm inside the motor compartment thanks to the lake temps (about 40F right now, and probably higher back on those frigid days that I foolishly discounted...)
I was going to weld this but now you see I have ground down into the crack, probably won't drill holes since this wasn't a stress crack to begin with, and will probably use J-B Weld since I am afraid to let someone weld/braze this for real AND also because since it is low-pressure and low-temp (it routes the lake water coming in from the water pump (which is at times heated up with the water that comes out of a hose that comes off the thermostat) so it shouldn't be very warm at all).
The hose that feeds the block mixes with the output water until the motor is warm, then I guess the thermostat closes off and feeds the motor cold water (?). The dude who had the boat before me had a cork in that output hose, down by the water strainer. I took the cork out since the motor was never getting past 120F . Now it gets to 160-180F. I never run it over 3K so I figure that is ok. But that is a different topic for later.
Tomorrow, I go back to the lake unless someone talks me out of JB Welding it at midnight tonight.... :^) That gives me 15 hours to let it cure then I put it together before dark tomorrow and fire it up and look for more cracks ....
ADDED: I have to make a gasket for the thing too. I bought some 1/64" gasket paper tonight at A*e and I am wondering if I should also use some gasket sealant when I put the gasket on . What do you think? I mean, since the piece is cracked it might flex more than a non-cracked one would.... HMMM.... and there is both oil and water contained under this plate.
I guess I will buy some gasket goo just in case.
#5 Posted : Wednesday, January 20, 2010 8:27:49 PM(UTC)
rmakkay
In my non professional opinion & not being a big fan of glues which all J B weld is (it may be good for stopping a leak in AL gutter but) for such a task it may hold up for a while & than let go at a very inopportune time while under way. If it where myself I’d have a competent welder do the welding or brazing with it being clamped to a welders table & cooled properly after the process there should be very little or no warpage to the housing if that’s your concern & I’d venture to say he do for less than $50. On the other hand if U are a do-it yourself guy at places like Home Depot in their tool welding area BernzOmatic sells brazing/welding rods for various application. Which I’ve used several times & had good success with. As a do-it yourself type guy myself I’d do the drill holes at the each end of the crack not all the way thru to prevent further spreading of the crack do to the heating while brazing & vibration after the task is completed I’d also filet the crack a fraction for better penetration & do it on the inner & outer sides if possible.
Well that’s my ½ penny’s worth good luck & hope it all works out for U if not try a boat bone yard in your area they’re sure to have some old scrapped out MoPar eng. laying around they’d be willing to part out just another ½ penny suggestion Well AnyWho Whistle
PS: Have U ever tried forma-gasket I use when changing out T-Stats
jimski2
#6 Posted : Wednesday, January 20, 2010 10:58:23 PM(UTC)
There is a company called "Metal Lock" that repairs cast iron cracks by drilling, tapping and screwing the cracks solid.
#7 Posted : Thursday, January 21, 2010 12:44:55 AM(UTC)
I'm very familar with "Metal Lock" used them on some dificult & impossible to weld castings. This is not a job fo metat lock, much to expensive and not needed. Just weld with brass or stainless. I Just hope that's all that is cracked??
rmakkay
#8 Posted : Thursday, January 21, 2010 1:14:42 AM(UTC)
rmakkay
Thanks for your replies, everyone. Norm thanks for all those ideas about DIY work. If I wasn't pressed for time I would have gone that route. I do need to get an oxy acetylene setup and learn how to use it. A torch has been on the list for a while now. As much as I like heavy baling wire and G*rilla Tape, the value of brazing rod isn't lost on me.
I plan to get a new casting someplace along the way. I chose to fix it with JB this time and as of today are looking for a used replacement. Any other suggestions on where to shop would be helpful. See the pic for a visual of the part needed.
Once I get a replacement part I will grind off the JB and try brazing it myself. I didn't want to risk someone else breaking the only part I have. I expect that the cast iron will continue to rust from inside and will eventually let the JB pop out and leak. A good thing is that the crack wasn't letting very much water out, it's above the water line, and the time to take the thing apart wasn't all that great.
And we don't go far nowadays -- normally go only a mile or two from the dock then park. So we can be in sight of a wireless connection. I have 428 feet of cat5e cable on a hose spool (run at 10Mbit when I have to use that excess amount) and can shoot wireless to the docs even with the boat tucked back into a cove. And you see why I didn't wait. I can go there today, drive out, and work tomorrow, Monday, etc. Skype for phone in a place where cell is unreliable or if I burn too many minutes, and shad and Silver Buddies for smallmouth off the back. The hardest multi-tasking ever known to man -- fishing and computing. LogMeIn and RDP works well. Let me know if I can help any of you with making the best wireless at your docks. I'll be glad to share what I know. 2.5 miles with a cheap hardware set (<$250 total) is my personal best so far. Most times I park the Marinette in sight of a dock's wireless and can repeat the DSL signal to a friend on the other side of the lake who has nothing more than a laptop. Wonderful.
And for Thanksgiving I made a wireless buoy out of things I found floating around and on the shore... LOL. To let me be on the "dark side of the creek". I take it out into sight of the dock and anchor it. An old ski rope I snagged while trolling one day (used for an anchor rope), an old cedar sapling for the upright, a funky algae stained green pool noodle I cut into 2" sections and use to float and make it obvious to protect my cable from boaters, and an old boat bumper to float the thing. I use a spare small anchor on the bottom of the sapling to keep it upright. I need to take a pic. Words don't do it justice.
Live and learn, winterize and braze. I hope to have the time to gut this boat this year so everything will be changing.
Thanks again. Send your spare baling wire and duct tape this way!
Rich
#10 Posted : Thursday, January 21, 2010 1:42:22 AM(UTC)
It's possible that this part is the only thing that cracked, but I'd take a close look at the block's freeze out plugs before anything else.
I hope I'm wrong, but I fear much more is damaged here.
rmakkay
#11 Posted : Thursday, January 21, 2010 2:06:32 AM(UTC)
rmakkay
Yeah, I'm afraid too -- but in my job, I am always expecting the worst but hoping for the best.
I looked at the freeze plugs and none popped out, none moved. One on the front, and three or more on each side.
Not even the beer bottle broke. And if it got REALLY cold all over (cold enough to break the block) then the bottle would have broken. It's in a plastic cup about 2" from the back of the boat. The only thing it doesn't get is breezes from the scoops.
On the other hand the part that cracked has the alternator bracket bolted to it on the side that cracked...... and I bet that acted like a big heat sink.
Quincy I'm not but it makes sense to me. A little breeze, a heat sink, water without whiskey, and a sad boater results. Change any of those factors and the results could have been much different!! ;^)
Will certainly let you know. This baby is going to be running on Saturday at the latest. Weather should be in the 50's here. A veritable heat wave!!
Rich
#12 Posted : Thursday, January 21, 2010 2:56:19 AM(UTC)
I assume it is your heat exchanger that cracked. If it is blow the waterline do not take a chance, replace it or fix it proper. You might arrive at your slip and find only your antenna's stickin out. If JB weld has already been used, good luck, you'll need it.
Had an exhaust manifold crack. The guys that fixed it drilled and plugged each end of the crack to stop if from traveling any futher. Then the baked it to 800*, welded it, and put it back in the oven for a cool down of 3 or 5 hours.
meltonhill
#13 Posted : Thursday, January 21, 2010 2:58:48 AM(UTC)
meltonhill
I would check with http://www.hurrikain.com/ChryslerMarineStore.htm they have a lot of older chrysler products. I looked at their website but don't see one on there but they might have one. I would refer to it as circulating water pump block off or something like that, I have one but mine is cracked where the double pocket impeller goes. Good luck.
#9 Posted : Thursday, January 21, 2010 6:45:30 PM(UTC)
rmakkay wrote:
...The hardest multi-tasking ever known to man -- fishing and computing...And for Thanksgiving I made a wireless buoy out of things I found floating around and on the shore...Rich
Fishing and gadgets...I like it! Glad you joined our forum MacGyver. Good luck on your projects.
DD
rmakkay
#14 Posted : Sunday, January 24, 2010 2:38:45 PM(UTC)
rmakkay
:^) Thanks.
OK, I got back from the lake. More to say than what I am about to say, but I think (and Jeff called it!!!) that maybe maybe I have a crack in the block.
The repair with JB held. So far.
I got the boat running to get it warm so I could change the oil (for many reasons as you know!!) . About a 1/4 cup of water came out first. ((((This doesn't look like something normal, but I am an optimist. Since the motor has many hours on it, and since it never gets hot, is it possible that blowby and the coolness could cause condensate to build up in the pan? ))))
If not, I have a cracked block ---------- and will drive this thing til it dies. We rarely cross 2k RPM unless in a bind (trolling and needing to protect our lines from runabouts, etc) and rarely go more than 2 miles.
So...... I changed the oil, and ran it at 4K RPM for maybe half an hour then , again drained a little bit of oil....pulled a cup of oil out and saw water droplets. I assume this is not leftover oil from the previous batch. Ha.
But like I said..... I will run this thing til it dies. Then I will put a short block in it.
LOL. I'm ready for a project! First , the inside. Going to get rid of the back bench seat , spin the head, expand the head room, and put a shower in. Then, replace the motor which should by then be tortured beyond any of its wildest dreams. My brother says that ya can't kill a 318 so what happens to a motor that fills with water over the period of a month? I'll drain the water out every trip if I gotta. Takes me about 5 minutes to tap the water out until the oil follows. LOL . Jeeze I'm so unconventional!!!! (I really do care about some things.... this isn't one of themm.....)
#15 Posted : Monday, January 25, 2010 12:22:45 AM(UTC)
If there's substanial moisture in the oil, it's hard to get rid of without an oil change or two. And if there's no functioning PCV system, you'll never get rid of the moisture.
Good luck!
#16 Posted : Monday, January 25, 2010 1:25:50 AM(UTC)
96 days to May 1 launch!
#17 Posted : Monday, January 25, 2010 1:34:55 AM(UTC)
I am afraid your season will be very short. Will not take long for your mains etc to freeze up from the water.
Low rpms etc will not extend the life of an engine with a cracked block.
Suppose to get down in the teens again by the end of this week in KY.
It is not unusal for freeze plugs to hold and blocks crack. In my experience they usually are the last thing to cut loss long after the damage was done.
Short blocks are easy to find but if you are not doing the work yourself I would suggest you get in line with a marina soon. This year in KY will mean there will probably be lots of cracked blocks.
I never fire off my boat until after April 15th. I am in the water all season also. Also your location of your test bottle was very close to the hull. The hull in the bilge will be the warmest area. Even though it is below freezing your underwater area will often reamin above freezing since it is below the waterline.
Your DSL wireless solution in interesting... by any chance are you related to Fastjeff? :)
Best of Luck,
Dave,
rmakkay
#18 Posted : Monday, January 25, 2010 11:10:46 AM(UTC)
rmakkay
It has no PCV system to speak of . Port side valve cover has a hose over the fill cap, and that feeds into the carb. Right side has what appears to be a PCV valve with a hose on it that USED to be connected to the carb. No idea why the carb, but it's disconnected now. Been that way for years.
I'm simply going to drain a cup of oil out at the beginning of every trip and see what comes out. Going to keep it close to the marina as usual, and maybe by June I will have an idea of whether or not the motor block is cracked.
My brother tells me that if I could block off the output hoses I could pressurize the system and be sure if the system is cracked or not. I will do.
THANKS AGAIN FOR ALL YOUR THOUGHTS . Tight lines and clean internet to ya all. Rich
#19 Posted : Friday, January 29, 2010 2:21:42 PM(UTC)
Freeze plugs don't protect the engine from freezing. An engine designer told me once that the "freeze" plug is to hold the sand cores that create the water passages during casting. They are machined and plugged with metal cups because that's the cheapest way to close the hole. Jeff probably knows if this is so.
#20 Posted : Friday, January 29, 2010 11:07:32 PM(UTC)
Correct, Mr Diesel Man.
The reason "core plugs" (their correct name) got called freeze (out) plugs by the public is that they pop out when the engine block freezes. When that happens, the block also cracks inside, just below the intake manifold and other places.
PS: Looking forward to your diesel web site.
2 Pages12>
This page was generated in 0.506 seconds.
