5 Pages«<345
Rebuild and repaint
#81 Posted : Tuesday, August 09, 2011 3:19:54 PM(UTC)
"Naval Architecture of Planing Hulls" by Lindsay Lord (c. 1946, 1954)
This book was the bible when Marinettes were first built, and was probably the reference used by the designers.
There is a copy on Amazon for only $200 (for a 300-page book!) so it is still well thought of. It is available online at http://www.ulib.org/
Dr Gonzo
#82 Posted : Thursday, August 11, 2011 10:53:12 AM(UTC)
Well...After 3 long years of waiting my boat finally splashed (Thank you Lord). The boat is resting comfortably at Gibraltar Boat yard and is in stable condition. Capac readings are 0.8...Not what I had hoped for but being that the new anode kit came with about 14' less material than what my boat had originally...Ill take it.
The keel of my 37 was drilled for two long strips of sea-alloy with the longest being on the bottom and running almost the full length of the keel and then with another strip just above that running 2/3 the length of the keel. The new anode kit I purchased from john ran short so my plans are to stay in the water for about 6 weeks and use that time to get all the boats systems back on line after 15 years of non use then haul out for the season and be ready to go first thing next spring.
Greg Came down to the boat after work yesterday and we fired the starboard engine and set the timing. Total advance was set at 30 degrees and their is no bog what so ever using the original stock carter carbs. We're planing on firing the port engine and doing the break-in tomorrow.
Thanks for all the help and I will report soon
Denis
Dr Gonzo
#83 Posted : Tuesday, August 30, 2011 10:32:18 PM(UTC)
I finally too my boat out on its first shake down run. engines ran fine except for one small problem. The port engine (counter rotating) exhaust manifolds ran supper hot and steam was coming from the exhaust off the back of the boat. The starbord engine exhaust manifolds ran cool. We shut down and checked everything and started the engine back up. We then ran the engine at around 2500 rpm out of gear and the manifold cooled down. We then returned back to idle and put the port engine back in gear and ran the boat back up to around 2500 rpm. all seemed Ok until the small section of brand new exhaust hose on the port side of the port engine between the riser and the y melted out the bottom.
Any thoughts ?. Both water pump impellers are brand new and their is no leaks at the strainers. The strainers even have new gaskets. Everything is new except the exhaust manifolds, elbows and the risers.
Is it possible that both manifolds are somewhat blocked up ?. But if thats the case then why would it be just the port side and not the starbord engine as well ? These are the stock manifolds that came with the boat since it was built.
Both the manifolds and the risers was getting too hot to the touch but the engine ran cool enough not to overheat.
If I have to replace the manifolds and elbows and risers ... what company should I go with. Osco or Barr. Osco was what we always went with way back when I worked on boats for a living ....but that was a long time ago and quality has changed dramatically over the years.
Thanks Denis
#84 Posted : Wednesday, August 31, 2011 6:21:05 AM(UTC)
I assume you have FWC or the motor would have gotten too hot as well. A couple of questions:
1. What is the water flow out the back? (Note: One should NEVER leave the slip without checking for water flow out the exhausts! If you don't do this now, PLEASE get into the habit.)
2. If there is flow out the back, how does it compare with the other side?
3. Was the raw water pump body worn when you changed impellers? If so, you'll need a new pump.
I've always used OSCO (they are in my state) but Barr is certainly okay. Price should rule.
#85 Posted : Wednesday, August 31, 2011 1:35:52 PM(UTC)
The fact that your exhaust hose melted suggests that insufficient amounts of raw water are reaching that part of your system. That can be caused by restrictions in the manifolds, risers, elbows or cooling hose. Are you sure the new impellers are the correct ones? The impeller (09959) from the 1" raw water pump will fit into the 1-1/4" pump (G-7) but will not pump sufficient water at idle or at high RPMs. As Jeff says, don't ask me how I know this. The correct impeller for the Sherwood G-7 (1-14") raw water pump is 10615.
#86 Posted : Thursday, September 01, 2011 1:29:23 PM(UTC)
Get one of those relatively inexpensive digital thermometers and take lots of reading around the manifolds, risers and other points along the cooling system. They are terrific devices for pinpoint temp anamolies. A guess: you have clogging in a manifold/riser. Have you checked impellers to see whether they are intact? Shards could break loose and jam the passages. Are they cracked and not functioning? All the items suggested above.
If it turns out you need a set of risers/manifolds for the 318 I have a spare set. Gently used.
Dr Gonzo
#87 Posted : Thursday, September 01, 2011 10:04:49 PM(UTC)
I did check water flow off the back of the boat and it looked the same as the other side. Impellers are the correct size for the pump. The water inlet is at the top (front) of the manifold and the outlet feeding the riser is coming off the top rear of the manifold.
I just pulled both manifolds off today and broke them down here at my shop. I really wont know anything till tomorrow when I take them to Greg's shop and put them in the media blasting oven and get them sparkling clean.
Because the water inlet is at the top of the manifold ...Im thinking AIR BUBBLE. I may re-plumb so that the water comes in from the rear of the manifold on the bottom and then feed the risers from the front top to eliminate the air pocket if indeed that's what is happening. First I want to make damm sure that all passages are clear and free from rust or debris and then do some water flow testing and see how things flow inside.
The manifolds look really good for being 30 years old but like I said....I wont know anything until I get them cleaned up and look around the inside with a bore scope to see how the water passages flow around the inside of the manifold.
Dr Gonzo
#88 Posted : Thursday, September 01, 2011 10:07:04 PM(UTC)
By the way....my engines are 440's not 318's
Dr Gonzo
#89 Posted : Thursday, September 01, 2011 11:25:48 PM(UTC)
my 440's
#90 Posted : Friday, September 02, 2011 2:26:51 PM(UTC)
Sorry I didn't think of air bubble when I first replied. Looking back over posts from years earlier, that has sometimes been a factor. Hope it's merely that.
Dr Gonzo
#91 Posted : Sunday, October 02, 2011 4:38:48 PM(UTC)
I broke down the manifolds, elbows and risers on both engines and found a ton of large rust scale plugging up the water passages on both engines. I took everything up to Gregs engines and we removed all the plugs and fittings and put the separate items in his 3 tier oven media blast system that made all the castings look like new again. I re-installed the manifolds after paying through the nose for new gaskets, o-rings and sleeves. I also re-plumed the water flow so that the water enters the bottom of the manifold at the rear of the engine and exits the top at the front of the engine so that theirs no chance of any air being trapped at the top. Now, the manifolds, elbows and risers run very cool and theirs twice the water flow coming out the exhaust. 2nd shake down cruise is planed for this coming Tuesday.
One of the marina services lost the steering bezel to the flybridge steering box so I now have a new problem. The steering system is a steermaster which is no longer made and I have to replace the entire steering system.
Has anyone here had to replace a dual station steering system on a 37 dcfb?. Anyway I look at it, its going to be a headache and expensive. I can go with a hynautic system or I can stay with a cable system. It comes down to what will retrofit the easiest. The last thing I want to do is open up Pandora Box trying to attach a hydraulic ram however the oil lines are easy to run but the entire system is stratospheric in price.
If I go with a new cable system the question then becomes "which one" and then I have to run all new mechanical steering cable which Ive done many times in my life and I can tell you it is the most exhausting job their is to do on a boat with a flybridge. Control cables are bad enough but new stiff steering cables are a damm nightmare. The last one I did was 25 plus years ago on a 31 chris craft flybridge for the guy that docked next to us and after that job I swore I would never do that job again.
Anyway I look at it, I'm in for a fight because I'm dealing with a dual helm system so the question now becomes which way to go.
Thanks Denis
#93 Posted : Sunday, October 02, 2011 5:41:09 PM(UTC)
I bought a couple of 180 degree click switches to mount to the water bend just downstream of where the water enters the exhaust. I wired them between ground and the alarm wire, along with the low-oil-pressure switch and the high-water-temperature switch. They will close if the flow of cooling water into the exhaust fails and set off the alarm. This should give me warning of a raw-water pump problem earlier than waiting for the engine itself to overheat.
I stole the idea from FastJeff.
mark klusman
#92 Posted : Sunday, October 02, 2011 7:11:35 PM(UTC)
mark klusman
Thanks Denis
Denis;
I had to replace my Steermaster cable, mechanical, and got a one from ( GLEN L Marine Designs ) Gave them a call and told them the # on the end of the beszel , its the lenght and had it in few days . No mounting change , everthing matched up perfectly. If you want to give them a call here's there #. 562-630-6258 . There web is, www.glen-l.com . I believe they have cable lenghts listed . If you don't want to go to hydraulic check them out. Got mine last year and can turn with one finger; one of the best $ moves i made.
Mark
Knot Normal
28FT. Express
Twin 318's
Ten Mile Tn.
Dr Gonzo
#94 Posted : Monday, March 26, 2012 1:18:18 AM(UTC)
I pulled out the steering cable for the fly bridge helm today and now the fun begins. I'm going to call Teleflex technical support tomorrow and see what its going to take to adapt their "Big-T" steering system to my existing steer master mk-2 linkage at the rear of the boat. The only issue I see is the rudder connection. It has a threaded tube for the cable jacket attachment and a threaded rod end for the clevis.
Pandora's Box. instructions...Place jar on ground...remove lid...and RUN LIKE HELL !!!
5 Pages«<345
This page was generated in 0.288 seconds.
