2 Pages12>
Capac .6
#1 Posted : Sunday, March 21, 2010 9:47:23 AM(UTC)
Think
Capac reading .6 with shore power disconnected.
Boat was pulled and Zinced 3 years ago.
Freshwater always.
I have not disconnected batteries and checked reading to rule out dc leak yet.
Checked rudder isolation. Did get a reading but it was very low. Should I be getting infinity?
Have not checked shafts yet.
Ideas? Brick wall
Anodes gone?
Would a cleaning of anodes bring it up to correct range?
Should I use a guppy anode until I can pull the boat?
Should I have the boat pulled immediately and rezinced?
Step by step ideas needed.
Thanks to all Applause
mark klusman
#2 Posted : Sunday, March 21, 2010 10:56:47 AM(UTC)
mark klusman
You might try and take her out from the dock ,and see if the capac reading goes up. As for mine , i read about .06 or .07 an a good day at the slip. Get out about a 1/8 mile and it goes up to a little over .08. Large marina , their not worried. I did make two guppys for the winter and attached to shafts and rudders. Don't know if it really helped but i didn't see where it could hurt . Tried all the things you mentioned but seemes to be the marina or other boats . I'm sure one of the guys can give you better info on what will help you get a better reading.
Mark
Knot Normal
28FT. Express
Twin 318's
Ten Mile Tn.
#3 Posted : Sunday, March 21, 2010 11:39:58 AM(UTC)
Agreed on taking here away from the dock and checking.
Also check to make sure the Capac meter is calibrated. I use a digital meter and make several small corrections until both units are reading as close as possible.
I'm not so sure cleaning the anodes will make a difference but if they have not been inspected for 3 yrs and have been in the water for that long, a haul out may be in order.
You may also have bottom paint coming off, exposing the Al which may cause some problems.
#4 Posted : Sunday, March 21, 2010 12:01:11 PM(UTC)
ANother view:
-cleaning often helps.
-if shafts and rudders are isolated properly, as they must be, attaching guppy to them should not do anything. Clamp one end to a piece of metal topside (like a rail stanchion) and lower guppy o'board.
-low Capac reading could be stray 12 v current from another boat, not a shore power issue.
-check shaft isolation. How-to has been posted a lot on the forum.
#5 Posted : Wednesday, March 24, 2010 5:06:35 AM(UTC)
Thanks for the advice.
I am getting a very small ohms reading on my rudders. Not sure if I should read infinity or if I will get a little bleeding from grease etc. Will rudder and shafts which are not isolated cause a low Capac reading, or is it strictly dc current and anode depletion? Think
#6 Posted : Wednesday, March 24, 2010 5:37:03 AM(UTC)
Have someone push and hold the Capac button while you ground the shaft(s) and see if the Capac needle deflects. If it does deflect, the shaft(s) are isolated. You can do the same w/ the rudder.
No needle deflection indicates the shaft/rudder is already grounded to the hull. This is not good and should be fixed.
#7 Posted : Wednesday, March 24, 2010 8:39:54 AM(UTC)
Thanks Karl
#8 Posted : Wednesday, March 24, 2010 10:38:06 AM(UTC)
I should have specified to ground each shaft to the hull, one at a time. I've used a pair of pliers from shaft to a clean, paint free stringer.
Its a good way to tell if the isolators are good on the shaft flange couplings.
I'm not so sure on the rudders. I really don't know how they isolated them from the hull.
I suspect my rudders are NOT isolated for one reason or another. That's first on the spring project list.
-K
#9 Posted : Wednesday, March 24, 2010 11:10:59 AM(UTC)
Look at the rudder bar and the cable connections. There has to be electrical isolation there (that some squid may have left off. The previous owner, of course!) If you have a ground, remove a part at a time 'til you discover where it is.
Dave Morris
#10 Posted : Wednesday, March 24, 2010 11:26:24 AM(UTC)
Dave Morris
Three year old zinc's , you got your money's worth !
5.8 Chryslers 275hp each.
#11 Posted : Wednesday, March 24, 2010 1:39:54 PM(UTC)
Thanks for your input on an old subject. I did a search, but you guys cleared a few things up for me. As soon as I check the isolation issue, I will have the boat pulled and rezinced.
Correct me if I'm wrong, for fresh water, I will be using Mil-Spec A-24779(SH) aluminum alloy (also called KA90 or SEALLOY 150 by Marinette Yachts) from boatzinc.com and magnesium on each trim tab Brick wall
If anyone else has more input please give it.
Thanks to all!! Applause
#13 Posted : Tuesday, March 30, 2010 11:14:13 AM(UTC)
1985, 29.5 foot sedan, twin 318s, freshwater
About to pull the boat for zincs.
Will be ordering from boatzincs.com.
30" on each side of keel
magnesium on each trim tab (which of these would you use? ?http://www.boatzincs.com/rudder-magnesium.html
6" on each rudder
magnesium on each shaft (what shaft diameter do I have?)
Any tips?
I think I have 1 1/4 inch shafts, is that correct
#14 Posted : Tuesday, March 30, 2010 10:51:46 PM(UTC)
Easy on the magnesium! You only need one block of it on a trim tab (though a second that's easily removable in-water would be okay). Use regular zinc anodes everywhere else.
PS: Too much voltage generated by your anodes will leach magnesium from the alloy, especially at the welds. Not good!
#15 Posted : Wednesday, March 31, 2010 1:05:37 AM(UTC)
You should first check if your Capac meter is working right ? There are write up in the archives
on how to check it out if it’s ok ( if U can anchor in the shallows take a very soft bristle brush on
handle & clean the Capac senor (very gently)see if that helps the readings? next step find where
U are getting the voltage leak from be it AC/ DC this is done easiest while the vessel is in the
water. Plus it’s a pain in the A$$$ but till this is done U will have problem if U over zinc or
magnesium U are creating a problem as bad if not worst as Jeff described. GOOD LUCK !!!
Over zincing is not the long term solution
#16 Posted : Wednesday, March 31, 2010 2:47:09 AM(UTC)
Jeff,
I am in fresh water, so I will be using Alum alloy on hull, etc and Magnesium no tabs.
#17 Posted : Wednesday, March 31, 2010 2:55:06 AM(UTC)
It will be June before I'm getting in the water around here...shrivel factor! I'm thinking after three years in fresh water the zincs are depleted. I'm planning on pulling the boat within the month for a bottom wash and a rezinc. I will be checking isolation and voltage leaks before pulling. You guys are the best. Happy boating!!
#18 Posted : Wednesday, March 31, 2010 3:17:53 AM(UTC)
One more thing: if your shafts are properly isolated (and they need to be), you really shouldn't need zincs on them. There was absolutely no wear on my shaft zincs are several seasons. Which means isolation was good, thankfully. That said, it's probably not harmful to keep a zinc on there. At least, you will feel better. And my guess is that you probably have 1 1/4" shafts. If you are not sure, buy the other size (1") and return the ones that don't fit. And re-read Norm's caution on scrubbing the Capac sensors - gently. I'd probably use only a sponge.
#19 Posted : Wednesday, March 31, 2010 10:19:28 AM(UTC)
Should I cover the Capac sensor while bottom cleaning or can I just hit it with a light pressure wash?
#20 Posted : Wednesday, March 31, 2010 1:29:23 PM(UTC)
I would definbitely NOT pressure wash it...use a sponge and a soft spray from a hose.
#21 Posted : Friday, April 02, 2010 8:34:25 AM(UTC)
Seems that I've read on the forum that someone suggested using a spacer/nut between the hull and the anodes which would leave a small gap so more anode surface would be exposed. Has anyone else done this? What are your thoughts?
2 Pages12>
This page was generated in 0.332 seconds.
