I can recommend pocosales as well, they are very good.
I like the look of toggle switches, and I always get switches to MIL-S-3950, which is the military spec for general high-reliability use. I have been using them for years and cannot recall ever having to replace one. A 15A on-off toggle is about $15 industrially, could be anything as surplus.
You can get them at alliedelec.com or newark.com. Skycraftsurplus.com in Orlando has mil switches, but they do not list them on their site, you have to call. Another good surplus place is
https://www.surpluscenter.com, I always try them to see if they have something I can use.
I use 15A or 20A rated switches for everything, smaller switches are the same money. I like the screw terminals, since it is a lot of trouble to replace a soldered switch, unless it is part of a panel that can be removed and taken below for work. I use a spring-return toggle for a horn, but many folks prefer a pushbutton. In any event, don't put anything on the flybridge unless it is waterproof. Don't trust those little rubber boots, they only protect the top of the switch anyway.
