marinettejoe wrote:Did you replace the thrust washer? Where did you buy it from?
I hope this isn't a double post; I just wrote a "Quick Reply" but it did not appear to post, so I'm trying this as well:
I did not use a thrust washer. The tiller arm is riding atop the bronze cast collar fitting at the top of the rudder between the tiller arm and the stuffing box. There was no thrust washer in the previous setup, so I'm trying it "as was", except that I am isolating the bronze collar and the rudder cable linkage from the hull. Previously the rudder (and the prop shaft
) were not isolated. If I wind up with too much friction between the tiller arm and the collar, I may add a delrin washer later on.
I bought the stuffing box from BoatFix.com for $58.64 shipped to Ithaca, NY. It arrived complete except for the hose coupling. I used a hose coupling from a local hardware store to connect the stuffing box to the rudder log.
